Question about Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by
Trying to put new cartridge in my moen bathroom faucet and i don't know how to do it. It is a teardrop one handle faucet. Please help a single woman not have to call a plumber!!!
  • 94 Answers
Shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
Posted on Apr 26, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do i fix my leaky moen bathroom faucet?
    Moen faucets are easy to repair. The cartridge you're looking for is most likely the #1224 cartridge, sold in pairs, and available at almost any home improvement store.
    Shut the water off, unscrew the handle, remove the nut that holds the old, cartridge in, swap it out, and put the handle back. The whole job should take you about ten minutes.
    Good Luck!
    May 21, 2014 | Plumbing
    I need replacement part for bath sink cartridge 4570
    The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
    Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
    Need to change washer faucet
    Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
    Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
    Leaky moen 2 handle faucet
    if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
    Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Moen single stem bathroom basin tap (25 years old). Trying to remove cartridge to grease it or replace it. Have removed handle and retaining clip. Pulled hard but can't shift it. Don't want to break...
    You are on the right track. You have to use some force when pulling the stem from the faucet. Your replacement cartridge should have a little black or whit cap. that is inserted on top of the cartridge and by turning the cap will help loosen the whole cartridge
    Feb 21, 2010 | Moen & One Handle Tub & Shower Faucet
    I just installed a new cartridge in a moen single handle bathroom faucet. Works great except no hot water. The hot water valve is turned all the way on.
    try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
    Jul 29, 2009 | Moen 3175 Legend One Handle Shower Faucet...
    Plumbing
    Hi rbyerly,
    I'm Harvey the Master Plumber.
    Your problem is:
    remodeled bathroom,installed new moen valve and hardware. Now water is coming from both the shower head and the faucet when the diverter is in the down postion. Question; Is this a single handle or three handle diverter? Assuming it's a three handle, it should just be a mater of adjusting the center handle. If single, the diverter is in the spout not the valve. I don't know how to direct you further without specifics. Feel free contact me again!
    Please give me a rating here at fixya.com before you sign off
    Thank you,
    Harvey your Master Plumber
    Oct 06, 2008 | Home
    Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by Logo
    477 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
