Question about HP PSC 1210 All-In-One InkJet Printer
Prints but won't copy - HP PSC 1210 All-In-One InkJet Printer
  • 1 more comment
  • pamodiosr Apr 25, 2010
    First Solution did not work!
    How do I uninstall and reinstall driver?
    Power off printer did not work!
    Do you reccomend uninstall and reinstall drivr also?
    If so, how do I do that?
    NO LIGHTS!
  • 977 Answers
Hi!
First of all, I wanted to say that the Copy function is totally independent and has absolutely NOTHING to do with the printer's software/drivers on your computer!
When trying to copy, do you get any error messages or does any led blinks differently than the usual?
Best regards,
Pelu.
Posted on Apr 25, 2010
  • Ran Kedar
    Ran Kedar Apr 25, 2010
    No lights AT ALL - and you do manage to print?! That's very strange...
    Have a look in this troubleshooting document. It should have all the information you need!
    President:
  • HP Master
  • 2,923 Answers
First, try to power cycle the HP PSC 1210. Disconnect the printer from the wall socket for 5 minutes, then plug it back in.
If that did not help, try to uninstall and reinstall the driver.
Last, scan your computer for viruses by updating your anti-virus software.don't forget to disable system restore and do the scanning in safe mode.
Thank you and good luck!
Typewriter won't Type
Put a multi part form in and type if it prints on the copies the ribbon is either bad, not lifting, installed wrong, not feeding or just old
May 09, 2012 | Smith Corona Office Equipment & Supplies
Keeps printing copies of what i copied last week and won't copy what i want this week
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel
it will be in the print queue where you can stop it printing right click to delete what you are printing you might have to uninstall the printer then reinstall to adjust your print settings
or just go into your printers settings to alter/change the settings
hope this helps
Jun 12, 2011 | Computers & Internet
Sharp line on print, even all new drumbs
Is it on prints and copies? Or just prints or just copies.
There are 4 likely causes if the line is on both prints and copies. 1 The transfer belt has a scratch on it. 2, The Transfer belt cleaner, called the IBT cleaner is worn, or the fuser has a cut in one of the rolls. Also the 2nd BTR roll located on the left hand door may be damaged.
If the problem is only with copies, then the scanner glasses or mirrors are dirty.
Mar 26, 2011 | Xerox WorkCentre M-24 Color Copier
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
ADF Pulls paper but prints a blank page
The wire ends have different sizes to avoid to connecting it to the wrong port. It will only fit to the right one.
If the copy prints a blank page, try copying again with the document facing up on the ADF.
Hope this helps!
Mar 03, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Error 9-363
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
HP PSC 1210 All-In-One InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
