Question about Toshiba Satellite A75-S211 Notebook
Laptop simply stops on starting
Can anyone help. my toshiba A75 s211 as soon as power button pressed, tries to start with fan coming on simultaneously and then just stops, power off.
  • Anonymous May 11, 2008
    My notebook was bough in March 2005 and has the same problem.
That used to happen to me as well; I know this may not sound like a solution, but give it a really good cleaning. This toshiba model has over-heating issues. Get some compressed air and go to town on it. Get the fans and all the slits on the back.
Posted on Apr 04, 2008
  • 3,587 Answers
Take out the battery, plug in ac only, and try it again
Posted on Mar 23, 2008
I have a Toshiba A75-S2112 laptop. I hit the debug button when it was booting up and now it will not boot-up to anything. It just sits there with a black screen and the fan turned off. I am trying to...
The computer starts but, when you press a key, nothing happens.
You are probably in Standby mode and have a software or
resource conflict. When this happens, turning the power on
returns you to the problem instead of restarting the system.
To clear the condition, press Ctrl, Alt, and Del simultaneously
then select Shutdown, then Restart to restart the computer.
Mar 24, 2011 | Toshiba Satellite A75-S2112 Notebook
Ok i did a clean install of windows 7 ultimate on my toshiba satellite a75 s211 then when i do that i cant hear so i get the latest realtek driver from the toshiba website i install it and i still cant...
Issue with your Hard Disk Possibility of bad sector ..on the primary sector... So Download Partiion Magic and Re- Partionnate your Har drive and Re install you windows
Sep 22, 2010 | Toshiba Satellite A75-S211: A75-S211 Intel...
My toshiba fans their a little noisy how bad do i need to replace
Two cans of compressed air can work wonders. I usually use both cans at the same time, just take the laptop outside and spray away. Make sure it's off, of course ;)
May 25, 2010 | Toshiba Satellite A75-S211 Notebook
My Toshiba A75 S211 os XP Home microphone is not working, is there a switch or something else?
Hi, from the "Start" search window: Type: microphone, select to open and configure to specification. "If the solution helped, rating it is appreciated , thanks.
Mar 17, 2010 | Toshiba Satellite A75-S211 Notebook
My Toshiba A75-S211 overheats and shuts off.
That is common with Toshiba. Check to see if your fans are running. Also, there may be a lot of dust, hair, etc inside the laptop causing it to heat up. I recommend buying a laptop cooler. I got mine for $10 and I never have over heating problems anymore. Hope that helps:)
Dec 29, 2009 | Toshiba Satellite A75-S211 Notebook
Toshiba Satallite a75-s2112 laptop when plugged into a/c power, the ac power stops working, then goes to battery. If I unplug the power adapter and plug it right back in , it will start working and then go...
This is a problem with your charger, I had the problem with my toshiba Sattelite, it was either a break in the wire or a short in the brick. You need to purchase a new charger.
Dec 23, 2009 | Toshiba Satellite A75-S211 Notebook
Toshiba Satellite A75-S209 (PSA70U-09700E) PC Notebook will not start.power lights come on for both the battery and DC. There is no fan or hard drive sound.power button does not light up. pushing the...
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Nov 13, 2009 | Toshiba Satellite A75-S209 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
    How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ... - 76k -
    Dec 31, 2008 | Toshiba Satellite A75-S211 Notebook
    Cant even get it to turn on
    Have you upgraded the memory on it? If you have more then one stick, then remove 1 and try it. Put that stick back in and Try the other one.
    Feb 29, 2008 | Toshiba Satellite A75-S211 Notebook
    Toshiba Satellite A75-S211 Notebook Logo
    95 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
