Question about Sony STR-DG800 Receiver
Sony str-dg800. Pre-amp out has no signal. - Sony STR-DG800 Receiver
  • m_mostert Apr 26, 2010
    I can't find the record out jack. I want to connect a Yamaha mx-630 poweramp that I got from a friend. (Yes it is tested and working) with Audio (L&R) cable. I plugged it in at the the jack marked Pre-amp OUT. I surfed the net and it seems if a few people have the same problem connecting to the DG800.
  • Larry Stiles
    Larry Stiles May 11, 2010
    Does record out have a siginal? If the rest of your amp works i think you may be hooked to an input instead of an output. What jack are you using what are you connecting?
    Champion:
  • 287 Answers
Hello. Jacks you are refering to are surround preamp out only. If you want full range audio out use video 1 audio out or video 2 audio out. The set does have a mono subwoofer out. You could have to go into the menu and turn it on but that is where you are to connect a subwoofer to . Larry's Electronics. ledstiles@hotmail.com
Posted on Apr 26, 2010
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
How to reset sony str-dg800 to factory settings
For the STR-DG800 you need to power off. Then hold power button 5 seconds. When "push entrer" appears on display push "memory/enter" button. System will turn off and reset.
Nov 17, 2010 | Sony STR-DG800 Receiver
Sony receiver str-dg800 will not power on.
Unplug the unit from the wall and remove the outer case. At the rear of the main circuit board is a fuse. Check the fuse to see if its blown. If not, go to the transfomer at the front of the receiver and check the fuses at the transformer.
Aug 28, 2010 | Sony STR-DG800 Receiver
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Need to save my pre set channels on the radio
once u have found the channel u want press memory button then the selected number, hope this helps
Sep 26, 2009 | Sony STR-DG800 Receiver
Sony Model: STR-DG800
You've got a short in one of your speaker wires either at the receiver (most common) or at the speaker itself. you should only have a 1/2" of each side of the speaker wire stripped to put on each terminal, and when you strip them, twist them so there are no frays in the strands that will touch the other terminal. The receiver is protecting itself from harm. Turn it off then disconnect all speaker wires, examine each wire carefully before reinstalling, then turn the receiver back on. If it still says protection, look at each speaker and reconnect your wires the same way. If you still have a problem, disconnect the wires again at the receiver and turn on, at this point, if it say's protection, it needs to be serviced. Hope this helps
Jun 23, 2009 | Sony STR-DG800 Receiver
Can't get Playstation3 sound through the STR-DG800 using HMDI.
Do you have your ps3 connected to the TV with HDMI and then audo cables from the TV to the receiver? If so, you need to make sure you change the audio settings on your TV to surround sound.
May 12, 2009 | Sony STR-DG800 Receiver
No Video or Audio on HDMI on Sony STR-DG800
The sony device may not be able to support the Toshiba. Make sure that is completely compatible and that you have the correct cables and setting to support everything.
Dec 31, 2008 | Sony STR-DG800 Receiver
STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Jul 06, 2008 | Sony STR-DG800 Receiver
Sony STR-DG800 Receiver Logo
294 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
