I hooked up my dvd/video recorder to my tv. when I play a dvd I get a picture, but no sound...what should I do?
  • 630 Answers
If you're using a SCART lead check that both ends are in securely. If using a S-VHS lead you need to use a separate audio lead
Posted on Apr 25, 2010
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Quite simple, I have an LG video recorder, and a Wharfdale dvdr24hd160f, both in line to my TV. Is there any way I can record old family video tapes to DVD, without interfering with my current wiring...
Hi, You should be able to depending on how your DVD is connected up. If it is hooked up using a yellow, red, and white lead (RCA. Common lead with a pin in centre of plug) there it should be no problem. On your TV there should be a set of sockets of the same colour. These should say monitor out, our output. Basically this set of plugs will send the picture and sound of whatever you are watching on the TV. If you connect from your monitor output sockets on your TV, to the input on your DVD recorder (will likely say AV1, or input on your DVD recorder) then it should record your video. You just have to make sure that the picture on your TV is the video you are playing, and the channel that is set to record on your DVD recorder is AV1. (You may also have an input at the front of your DVD recorder that says AV2 or input 2.) As long as you set your DVD to record the input set of sockets you plugged your cable into it should work. This set up will not alter the operation of your DVD or TV.
Oct 26, 2009 | Televison & Video
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Samir
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
No picture
check the cables it sounds like they are connected wrong do you have more than one input on the tv ? you can only run one of the devices at one time let me know
Dec 13, 2007 | Philips 34PW850H 34" TV
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
