Question about Apple PowerBook G3 Mac Notebook
I canot install os 9.2.1 on PowerBook G3 Series (M5343) I keeping getting a disk with ?. There harddrive activity Formated with my macbook pro as mac journaled. I'v tried the Pram reset many many times no luck. I canot get into single user mode Commad+s or just s will not work. please help...
  • russellh Apr 26, 2010
    Yes done that but I still get diskett with blinking ?
    Ya just tried that again same disk blinking ? shut down about a min later? Any other ideas?
  • Apple Master
  • 4,924 Answers
See maybe it asks for a 3rd party driver ..like raid in pc...(equivalent ) if does,, this may be present on the drivers disk that came with it ...when it asks insert the disk and let it copy it ..and continue...or if you have a floppy ..insert in parallel a disk-ete wilth the driver it asks for..and it will continue..you may also try with a usb stick ..and put all drivers you have on it ..and let it choose (just show the path..) or ..if it asks for a certain driver browse for it ..but in this conditions it may need a usb driver..
another posibility is that the disk you are trying to install from is damaged..so if you have the possibility burn another one ...cause if it is scratched or so ..it may not read some files...
Posted on Apr 26, 2010
  • 560 Answers
If you have an external harddrive enlosure, attached your G3's harddrive to your MacBook Pro. Launch your Disk Utility. Applications folder > Utilities folder > Disk Utility. Select the hard drive in the left hand column and click on the Erase tab.
Posted on Apr 25, 2010
  • 1 more comment
  • Liza Halbrook
    Liza Halbrook Apr 25, 2010
    After erasing the drive, put it back to your PowerBook G3, boot from 9.2.1 CD and do a fresh install.
  • Liza Halbrook
    Liza Halbrook Apr 26, 2010
    Select the Volume Format "Mac OS Extended" not journaled. Do NOT check the "install Mac OS 9 Disk Driver".
  • Liza Halbrook
    Liza Halbrook Apr 28, 2010
    When adding comment, please quote the name of the solution provider so I would know if you are referring to my solution or not.
    Did you try to erase the partition? What is the result? Were you able to erase successfully?
What cords are needed to hook up hp7300 series printer to powerbook G3 laptop
Probably just need a usb a-b printer cable. One side is square-ish with a rounded side and the other end is a regular usb
Jun 22, 2014 | Apple G3 Computers & Internet
Reinstalling system software
Good question, the wall street is the same as the Pismo. A great and simple machine. I recommend using os x 10.4 as the highest level. You install the system disc in the optical drive and restart it from its pop up menu. then it will prompt you for each step. You can also hold down the option key on startup to select the disc to boot from.
There is a list of key commands on apple support. Easy way to do it is to just let the disk prompt you after it restarts.
Jun 10, 2014 | Apple PowerBook G3 Mac Notebook
I have Mac OS X 10.5.8 need to upgrade to 10.6
The PowerBook G4 line was the last generation of the PowerBook series, and was succeeded by the Intel-powered MacBook Pro line in the first half of 2006. The latest version of OS X any PowerBook G4 can run is Mac OS X Leopard, released in 2007.[
Your computer is too old.
Mar 18, 2014 | Apple PowerBook G4 Mac Notebook
Download os x 106 free
I cant remember my macbook Pro password
Your best option is to use a Mac OS X install disk. Insert the disk, hold the 'C' key to startup from the CD drive, and there should be an option to reset your Administrator password. The details will depend on the version of OS X.
Aug 02, 2012 | Apple PowerBook G4 Mac Notebook
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
Apple Mac PowerBook G3 M5343
since apple drives are formatted in HSF+, a file system that windows cannon read, the chances of it even being bossible to run anything on it from a PC is very very slim.
Jan 18, 2010 | Apple PowerBook G3 Mac Notebook
I have a macintosh powerbook G3 and i forgot password
If you are running OS X put the appropriate system disk in the disk drive. Boot up using the c key. Once booted go up to the file menu and go to the reset password menu and reset your password. viola
Oct 07, 2009 | Apple PowerBook G3 Mac Notebook
I am trying to download the latest version of adobe adobe flash player onto my macbook pro OS X but it is never being completely downloaded. Itried the version 9 of adobe and worked but not with version...
sometimes with notebooks etc the manufacturer puts administrator restrictions to stop you installing active x, if the macbook is working ok with version 9 I suggest you keep using that version, however if you wish to install version 10 go to the adobe site and ask for assistance or read the troubleshooting guides, but they will probably tell you the same as I have.
Nov 06, 2008 | Computers & Internet
One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Feb 08, 2008 | Computers & Internet
Apple PowerBook G3 Mac Notebook Logo
201 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
