Question about Samson M15 Microphone
My M1 Samson Microphone isn't working. I need some help I have it in the computer microphone slot. I want to be able to record music using windows. It works great on a Karoke system. The package said it was useable via through computer.
4 Suggested Answers
SOURCE: tips on Using the Samson C01U with Cakewalk Pro Audio 9
Try this:
Control Panel > Sound Audio Device > go to Voice Tab > check your drop down list for Voice Recording and make sure you put on Samson C01U then test your hardware and see you get any pick up. I had to research on what to do.
Now my problem is why the mic is only picking up on the left side of the ear instead of the right. =/
Posted on Jan 08, 2009
SOURCE: Samson C03 Microphone using with Realtek HD Audio Manager
SEU MICROFONE PRECISA DE UM RECURSO CHAMADO PHANTON POWER QUE NADA MAIS é DO QUE UMA ALIMENTAçãO DE 48 VOLTS, PORTANTO NECESSITA DE UM APARELHO INTERMEDIARIO, COMO UMA MESA DE SOM COM ESTE DISPOSITIVO OU UM ADAPTADOR PHANTON POWER COM SAIDA USB PARA O SEU PC, NO CASO DA MESA TAMBEM é NECESSARIO UMA PLACA DE AUDIO COM CONEXãO USB EXEMPLO UCA 202 DA BEHRINGER , PODES CRER Só ASSIM FUNCIONA E SOM é MUITO BOM.
Posted on Aug 06, 2008
  • 135 Answers
SOURCE: I just today bought a Samson R21S microphone, and
Not really the mic's fault - just incompatible.
Your Samson mic is a "dynamic" type and the laptop is expecting a "condensor" type.
You could put the mic through a preamp first but easier to exchange for a more suitable type.
Hope this helps.
http://stores.ebay.co.uk/methleykev
http://www.technicsdjuk.com/
Posted on Jul 12, 2010
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
If the acer 5532 has a microphone - where is it and how does it work. Is it possible to record live music?
Hi there.
The 5532 should have a microphone as it has a webcam in it. If not there is a microphone jack at the left side of it.
If you want to test your microphone there is an application called sound recorder. It is located in Start - all programs - accessories.
You can change the properties for the microphone if you right click on your speaker icon at the bottom right of your task bar (bottom right of the screen) and click on recording devices. This is assuming your computer has Windows 7 which I think it does. In this screen it will show all connected devices you can use for recording.
A recording application you can try is called Audacity. You will need to google it. It is a music recording program that is free. It isn't the easiest to use though. If you want to record live music you can use the sound recorder to record it as well.
If you have any other questions leave a comment and I can get back to you.
Sep 13, 2011 | Acer Computers & Internet
My samson microphone c01u works but i cant hear my mic thru my speakers it does not record out
That's normal. You're supposed to record a track and then play it back. In order to hear it live you would need to enable "software playthrough" in your recording software, but there will be a delay, so it probably won't be much use.
Aug 27, 2011 | Samson Audio C01upak C01u Microphone and...
My Samson C01U microphone doesnt seem to be working. the green light doesnt turn on when i plug it into the usb port of my computer. I have windows vista. Is it not compatible?? The computer says the...
Sorry this isn't a solution but just letting you know I'm having the same trouble, the funny thing is mine was working a couple of months back and now its not, it's driving me crazy.
May 19, 2011 | Samson C01U Consumer Microphone
I connected the microphone on my computer and the system rec.ognized the microphone but I don't know how to use it with the computer to bring out sound
The thing is that the Samson C01U was not designed for live applications. Your solution, if you like delayed sound, is to use Virtual Audio Cable. Otherwise, I would get either a Samson GTrack, or invest in a cheap but functional mixer with a good mic. If you want to record however, you go into your audio recording settings and select the C01U as the recording mic. If you record and hear little sound, go into sound manager... Click on properties and select on Samson C01U. A one channel volume control will pop out. change the volume and record. BTW, a good audio program is Audacity... It's free. I hope that I have helped you...
Apr 27, 2011 | Samson C01U Consumer Microphone
How do i get my samson c01U mic to work with windows vista and cubase le?
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Apr 21, 2010 | Samson Audio C01upak C01u Microphone and...
My Samson C03U Sound
i am using samson c03u to record songs using magix music maker, never had problems with it until i fell pregnant and gave birth so i stopped using it for a while. now that im back to record songs again, i started recording and everytime i playback the song i recorded, the music is fine but my voice started jumping like a pirated cd. im using windows vista and i already tried clearing the junk and re installing the programs but it still does the same thing. please help if anyone's got an insight about this. Ta
Oct 28, 2009 | Samson C03U Professional Microphone
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson M15 Microphone Logo
874 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Umali
Vito Vacirca Jr.
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
