Question about Bosch 23 in. SHU3302UC Built-in Dishwasher
I have a bosch shu3002uc that is leaking at the bottom of the door. I have to put sponges on the floor to catch the water. What should i do?
    Problem Solver:
  • 17 Answers
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Posted on Oct 18, 2010
  • 229 Answers
Check the levelness of the dishwash. Is it level.
Check the seal around the contact surface of the door and the washer opening. Are there any cuts or gaps?
Posted on Apr 26, 2010
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
Error message F:21. Bosch
Take the kick panel off and see if there is a tray under it to catch leaks. If it has water in the tray, that is the problem.
Jun 18, 2013 | Washing Machines
Fridge working perfectly... water leaks onto floor over night seems to be from underneath..
I would check that the water catch tray is on the compressor, this item collects the water from a defrost, it may be missing.
Dec 04, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Door leak on built in LG dishwasher.
Check and make sure the unit is level front to back and side to side.
Check all 3 spray arms for plugged or restricted holes that may be diverting water in the wrong direction..
Jan 05, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
My bosch 1200 classixx WAE24164GB will not spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate.
Pl rate me 'very helpful' for the free help, thnks!
Oct 26, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Bosch Calssixx 1000 Express Washin Machine
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Pl rate me 'very helpful' for the free help, thanks!
Sep 08, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Rugs won't dry
Jun 22, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Dishwashers Logo
215 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
