Question about GPS
I have a nuvi 265wt that only produces voice prompts for the first 2 or 3 streets of any trip, then is silent for the remainder of the trip! All the while, the mapping software works fine from start to finish. I have tried Garmins webupdater to download software, but that did not help. Any suggestions on fixing the problem?
  • 3 more comments
  • pat9427 Apr 26, 2010
    I tried that fix, and it did not fix the problem!
    I have a nuvi 265wt that only produces voice prompts for the first 2 or 3 streets of any trip, then is silent for the remainder of the trip! All the while, the mapping software works fine from start to finish. I have tried Garmins webupdater to download software, and also tried restore,but neither solved the problem!
  • pat9427 Apr 27, 2010
    The sofware on this unit was pre-loaded, and the Garmin website appears to only include various updating software, as opposed to the software that is pre-loaded. Also, do not know how to backup the existing software on the unit!
    I have a nuvi 265wt that only produces voice prompts for the first 2 or 3 streets of any trip, then is silent for the remainder of the trip! All the while, the mapping software works fine from start to finish. I have tried Garmins webupdater, and tried the restore feature on the unit, but neither solved the problem. Could this be a hardware problem, as opposed to a software issue?
    Thanks
    Pat
    I do not have an SD card installed, however, I am the second owner of the unit, and an SD card may have previously been installed. Do not know if this makes a difference! The only reset that I am aware of is the restore function, but am not sure. Please reply!
    Thanks
    Pat
  • 668 Answers
In settings turn the map outlines off. Then check for voice prompts .If you still face the problem then there is defect in your unit ,You need to contact garmin for replacing it .
Hope this helps .
Posted on Apr 28, 2010
    Guru:
  • 374 Answers
I had the same problem on a different brand. I did a full reset and I deleted all the extras I had on my SD card. How full and what is the size of the SD card??
When I reset it,everything went to the factory setting and it seemed to clear the setting and went back to normal.
I believe mine was running out of memory as I had some MP3s and movies on it.
Let me know how it goes and lets get this going again!!!
thanks and hope I this helps!
Posted on Apr 27, 2010
    Genius:
  • 1,341 Answers
I would suggest to reinstall the application on it.Back up everything before you install the software.This should solve your problem.
Posted on Apr 26, 2010
  • heeman mohun Apr 27, 2010
    If you connect the sat nav to a computer via usb, you will notice that it will appear as a new hard disk or storage device under my computer control panel. Once you see the device appearing you can browse the files and or back up these files in a new folder under your actual pc. Now if it comes preloaded with this software, do you have any cd that came with this unit at the time of purchase? You could try that. Else you can do some google search for some compatible software that will work on this unit.I got Garmin to work on my nokia 5800...The idea is that nothing is impossible if you search carefully for the right software.
  • 344 Answers
Try restoring settings,
1. Touch Tools/Settings
2. Touch Restore
3. Touch Yes
Posted on Apr 25, 2010
HOW CAN I GET THE VOICE PROMPTS TO WORK ON MY NUVI
Normally on front of screen there is promp for voice to mute or un mute, but if you don't see that go to settings and look for voice controls. But like I said is normally on screen right side area looks like a circle kind of.
Jun 08, 2011 | Garmin Nuvi 265W GPS Receiver
My Garmin Nuvi 760 GPS announces the turns but not the street names.
1. This is because some voice files are only basic but others speak the street names. To change the voice file press TOOLS, then press SETTINGS then press LANGUAGE. Press the VOICE and change it to a different one.
2. You can download extra voices, if you need to, by connecting your satnav to your computer, Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it. When it's installed it'll look for software updates. After this it'll give you the option to download extra voices. Select the ones you want and press next. Follow the prompts and they will be downloaded to your satnav. When you have disconnected your satnav from the computer you can select a new voice as described in para 1 above.
Aug 19, 2010 | Garmin Nuvi 760 Car GPS Receiver
After a map update my garmin 265 wont talk
I recommend reupdating your Nuvi 265WT with the newest firmware, and then performing the Hard Reset a second time afterwards to ensure the 'voice' functions come back on.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Oct 01, 2009 | Garmin n?vi 265WT Car GPS Receiver
Garmin Nuvi 265WT voice prompts tell me way to late to turn as I approach turns and intersections. Many times I am already pass the left or right turn lanes before I am told to turn. Also addresses and...
I can help you fix the satellite problem with your Garmin Nuvi 265WT.
Poor or inaccurate GPS tracking, and taking a long time to acquire satellites, are issues that have been addressed by Nuvi 265WT firmware updates.
There are three steps to take to get your Nuvi 265WT running better than new:
I hope that helps.
Jun 05, 2009 | Garmin Nuvi 660 GPS Receiver
How do you get GArmin nuvi 265WT to speak street names?
I just purchased similar model (Nuvi 265W) and experiment for sometime. The trick is on the language option with or without TTS.
Select Setting from menu, go to language and pick the Voice option. Select any one of the language with TTS (Text to Speech) and save. Those that without (TTS) will not talk "street name", this is why some cheaper model can't speak street name, only turn-by-turn instruction, like nuvi model 205.
Enjoy
Apr 11, 2009 | Garmin nuvi 205W GPS Receiver
I have a Nuvi 255. It does not speak street names
Did you select Text To Speech (TTS) one?  If the voice doesn't have (TTS) it won't speak street names.
Mar 29, 2009 | Garmin nuvi 255W GPS Receiver
Voice prompt and more
First go to Menu > Tools > Settings > Language (icon is red lips)
You will see three settings: Voice, Text, Keyboard.
The voice setting may be blank. That just happens. Touch and be sure to select "American English, Jill or Jack, TTS. The "TTS" is very important in that it causes street names to be spoken. Example: "Turn left on Main Street." If you choose a Voice Language that is not TTS, as are the first selections shown, you will get commands without street names. Example: "Turn left." but it won't say the street name. After you have done this the 760, and maybe other models of the nuvi, will lose this setting on a random basis. Everytime it goes silent you have to redo the process of setting up the voice language. Who knows why?
Jan 13, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin wont read street names anymore
To activate the voice prompts, go to 1. Tools, 2. Settings, 3. Language, 4. Voice Language Option, 5 Select a Voice Option that includes a persons Name, eg Jack or TTS, Select OK and that should resolve your problem.
Dec 08, 2008 | Garmin nuvi 200W GPS Receiver
Gamin nuvi 260W - Cannot set to text-to-voice.
Garmin automotive GPS devices that have text-to-speech (speak street names) are also loaded with pre-recorded voices that do not speak street names (example: "Turn Right in 500 feet"). If one of these pre-recorded voices has been selected, the voice prompts will not speak street names.
To change the voice prompt to spoken street names:
  1. Touch Tools (Wrench icon) from the Main Menu
  2. Touch Settings*
  3. Select Language or Locale
  4. Touch the Voice language option
  5. Select a voice option that includes a person's name (ex. Emily) or TTS. Options without a name or the TTS label will say the distance until the next turn, but will not include the street name.
  6. Select OK
The device should now speak street names.
*Note: The Setting option is not required on all nuvi units.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Aug 17, 2008 | Garmin nuvi 260W GPS Receiver
Street names
http://iq.garmin.com/eCustomer/KODSelfService/request.do?session={ed995d70-c2e6-11dc-6a6e-000000000000}&event=1&view()=c%7Bf996f590-047f-11dc-e004-000000000000%7D&objectId=&eksObjectId=&objectType=Case&isJumpEnabled=false&isContentJumpEnabled=false&vendorKey=&versionId=1301&objectScore=82&from=search
Question
: My nuvi is supposed to speak street names when giving voice prompts but it doesn't. How can I fix this?
Answer: All of the Garmin automotive GPS units that speak street names are also loaded with basic voice prompts (i.e. 'Turn Right in 500 feet') as well as 'text-to-speech' voices that speak street names. If one of the basic types of voice prompts has been selected, the voice prompts will not speak street names.
In order to change this setting on the nüvi line of products, please follow these steps:
  1. In the Main Menu, tap on the Settings icon.
  2. Tap on "Locale"
  3. The second line on this screen has a picture of a mouth. To the right, the current voice for the GPS device is listed. Tap it to change the voice.
  4. Select a voice that is labeled with (TTS) at the end. These voices will speak street names.
  5. Select "OK". The voice has now been changed.
Dec 22, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
