Question about Gaggia Classic Espresso Machine
No water coming through ....makes alot of noise but no water
    Scholar:
  • 32 Answers
Check this thread: http://www.fixya.com/support/t2527967-no_water_coming_head_after_prime_etc
Posted on May 29, 2010
Hi Karen.
I'm having exactly the same problem with my Gaggia Classic. I have just been trawling through the gaggia problems on this page and have come across several possible causes and solutions.
I have copied and pasted them onto a seperate page as I know I'll never be able to find them again.
Search this site and if you have no luck I can email the page I copied.
rdw314@yahoo.co.uk just put Gaggia in subject box.
From what I gather it could possibly be a bit of lime scale that has broken off and clogged the water pump.
Good luck and don't hesitate to email me if I can be of any help
Regards
Robert
Posted on Apr 27, 2010
Machine is making alot noise during the spin cycle, and it also shuts the water off during the rinse cycle
Noise could be several issues motor, tranny, clutch. But as for the water issue make sure that the cold water side of the valve on the back of unit is clean. Remove hoses and look for plugged screens.
Jun 03, 2011 | Estate ETW4400VQ Top Load Washer
Engine makes alot of noise
There can be many reasons for the noise but if you can pour some water on the fan belt and the AC belt while the engine is started and if the noise drops off then the belt can be faulty. Also check the pulley idler, check the water pump. If not there can be faulty timing chain , idler or within the engine.
Feb 18, 2011 | Car Audio & Video
Audiobaun 1800-dt amp smoked now have alot of engine noise
depending on the the amp make, it might be a resistor or a fuse that burnt in the grounding circuit, explaining the engine noise
Apr 29, 2010 | Car Audio & Video
When running load noise coming from black cylinder
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
Dec 10, 2009 | LG LHD65EBL Dehumidifier
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
Electric cooling fan on 1998 volvo s70 makes alot of noise when it comes on
Replace it. The bearings are going bad, or the blade.
May 30, 2009 | 1998 Volvo S70
I have a GE front load washer model # whdvh626fww. it keeps making alot of noise when in the spin cycle and the belt keeps coming off. at first I thougt it was out of balance but that was not it . when I...
I have a different suggestion based on my washer's similar problem. If the black stuff is powdery and localized at the back of the unit, more than likely the culprit is the drum pulley itself is warped, causing the belt to chafe against the drum. The black powder is rubber residue from the scraping of belt on plastic. No need to replace unit. New belt and new pulley run about $70 each.
Jul 19, 2008 | GE Washing Machines
Washer machine Won't drain
more than likely that it is blocked pull the washer clear so you can see the back get your outlet hose and place into a bucket and see if the water comes out if it doesnt than pump/pipe blocked better off taking washer outside because when you release the outlet pipe from your pump thert will be alot of water that will come out if it comes out of the pump than your pipe will be blocked m8
Aug 14, 2007 | Tecnik TKL9260 Front Load Washer
Gaggia Classic Espresso Machine Logo
482 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
