Question about Motorola Mobility RAZR V3xx Cellular Phone
I need a bootloader for my v3xx - Motorola Mobility RAZR V3xx Cellular Phone
How to unlock Razr V3xx Bootloader 03.08 SW Version R26111MLD-AS_U
Try calling the provider that you got the phone from and asking for the unlock code -- they should give it to you. If that doesn't work, you could go to this: http://www.gsmliberty.net/shop/motorola-razr-v3xx-imei-unlock-codes-p-1978.html website and pay them $10 to provide you with the code, though that's probably not the best option.
Mar 05, 2011 | Cell Phones
How to restore motorola v3xx in to factory defult settings?
you can not get to the factory reset menu if it is starting in flash mode,so go to www.modmymoto.com download p2k phone tools.that will let you flash the phone back
May 10, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
Use the phone
your phone is starting in flash mode..try and hold the palm key and the star key at te same time while turning on your phone.. that is the way u start a razor in flash mode,,mabey it will take it out of that mode
Feb 17, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola razr v3xx is stuck on bootloader how do i reflash or solve this problem?
At this point, I'd make sure the * # and Power keys are not depressed by any chance. Maybe they are stuck. I'm afraid it might be a hardware issue, the only suggestions I could make is to flash a monster-pack but this would most likely not work and will erase anything on the phone anyway.
If not, try using Flash & Backup 3.0.7 and see if it detects your phone. If it does, try backing up ur current software and then try to flash a compatible MP (Monster Pack) from http://www.modmymoto.com/forums/downloads.php?do=cat&id=142
Try that.
Oct 20, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Bootloader 03.02 sw version r26111ld_u_96.66.73br
This website will send your phone the correct software. Follow the directions and you should be god to go.
Please leave good ratings, they are important...
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=69fd5fc943dc0210VgnVCM1000008806b00aRCRD
Aug 05, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
I am trying to find a free unlock code for my v3xx. Please help me!!!!!!!!!!!!!!
I should first point out that there are other options to unlocking yourself,
1) You can get the unlock code from your provider for free if they areprepared to give it to you. If they are then that is the safest andbest option.
2) There are also remote unlocking services - google GSM liberty
3) If you have or know of someone or a store with a smart clip these can be used.
To unlock yourself:
*You need to downgrade your boot loader - this is very risky - no liability is accepted for any problems that may occur*
Ensure your phone is fully charged before starting.
I recommend before beginning you first make a backup of your phoneas described in the How To: Use Flashbackup To Backup Your Phone topicin the tutorials section.
This assumes all necessary drivers are already installed.
1) Start in bootloader mode (hold # and * while powering on)
2) Identify your current bootloader (e.g. 8.26 or 7.E0)
3) If you have bootloader 7.D0 already skip to step 6
4) Download and extract http://www.poeticfolly.com/motoguide/gurus/unlockit/bl_826-828_to_07d0 _for_V3_by_Archy.V2.shx
5) Use RSD Lite (This program is considered Warez and links are notallowed - search google for it) to flash the file to your phone
6) Download and extract the Moto Unlocker software from http://www.poeticfolly.com/motoguide/gurus/unlockit/Motorola_Unlocker_ 2005.zip
7) Start in bootloader mode (hold # and * while powering on)
8 ) Run Moto Unlocker click connect and yes
PROBLEMS:
If after running motounlocker you still have issues there are two options:
1) Flash an old monsterpack (circa 40.79R), run the unlocker again then flash a recent monsterpack
2) Find P2k Easy Tools cracked version using google
btw I cannot take any credit for this - credit is due here:
http://www.motox.info/showthread.php?p=53127#post53127
and to Scotty2 and Archy for the bootloader downgrade
Jan 26, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3c will not power up.
USB INIT has failed on the phone you will need to take the phone to a professional mobile service center and have them fix it for you.
Aug 02, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
AT&T V3xx no operating system
take the phone to a mobile store to have it unlock the correct way the phone was in it's unlocking state but the person did something wrong and ahve it stuck in it's test mode.
Apr 27, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Phone will not boot up
have your phone reprogrammed..i think it's corrupted
Jan 27, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Mobility RAZR V3xx Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
