Question about Garmin GPS
Garmin c530 wont power up. Did it once, took it apart and worked for a few days, died again.
Did you reset it? lift off the cover plate by slipping your fingernail into the little slot just beneath the Garmin logo. There is a reset button hidden under the cover...
Posted on Apr 18, 2008
My Garmin c530 GPS will not turn on
Pull the face off it, press the reset button, this may work,
If it will not reset, or work in the house or the car, the battery will need replacing,
http://www8.garmin.com/support/outofwarranty.html
Around $100 for new battery
Regards.
Jun 21, 2009 | Garmin StreetPilot c340 GPS Receiver
I have a garmin street pilot c530 after i power it up and agree to the disclaimer the screen reads as follows no deailed maps found that support routing street pilot cannot be used without them the unit...
I just purchased my c530 a couple of days ago and had been loving it. I had added some custom POI's to my sd card using POI loader version 2.4.0 and that had worked fine. Then the other day I tried to load some new custom POI's, but POI loader got hung up and froze. After disconnecting the c530, I restarted it. After it started, a screen came up that said "No detailed maps found that support routing. The Streetpilot cannot be used without them." I contacted garmin, here is the site for contact info since I am unsure where you are. http://www.garmin.com/garmin/cms/site/us/support/supportcontactand the tech support at Garmin. They said that somehow the files on my c530 must have gotten corrupted. The person I talked to at Garmin was very friendly and walked me through several things trying to get my unit to work. He was very apologetic and said that this should not have happened. He told me I would have to return it and get a replacement. Sorry Hope this helped.
Jun 09, 2008 | Garmin GPS
Garmin c530 does not turn on
Replace the battery 3 years is the maximum life of the battery
Jun 11, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 powers up breifly then shuts down
The problem is with the battery, DC will not fully charge the battery to its required capicty to work. You need an AC charger and to charge it fully ( 10 hrs Max) and then try it. It needs a lot of power to drive the screen and connect to satellites.
Invest in an AC charger and all should work properly
Jun 07, 2009 | Garmin StreetPilot c530 GPS Receiver
Deleted memory for garmin c530
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express. https://support.garmin.com/faqSearch/en-US/faq/content/b17m7lCO3R4UKUAt8x67J7
Mar 21, 2017 | Garmin StreetPilot c530 GPS Receiver
Garmin GPS will not work
tape holds strip cable down, could have got hot in window and loosen the tape. pull front panel out, very carefully, 4 screws secure the unit, It will snap apart, so start looking inside ffor the brown tape in the rear protion of your GPS
Mar 21, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin C530
There is a Master Reset procedure, but you would lose all of your favorites if you did it. To do a Master Reset, turn the unit off. Press and hold the on button and the bottom right of the screen at the same time. Release the on button when the unit comes on and asks if you want to do a Master Reset. Again, this will ERASE ALL OF YOUR FAVORITES.
Mar 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 won't turn on
Have a c530 I purchased 11/2006. In 12/2006 had 3 instances where I shut unit off and it would not turn on. Garmin had me do resets which did nothing. Had to leave unit to discharge for 3 days, then plugged in USB and it powered up and was fine (for a week or so). They gave me a new unit and at the same time a system software upgrade was available. The c530 was perfect through all of 2007. Then in Jan 2008, the same failures occurred 3 times. I discharged it 3 times and it now works, but for how long? My advice is to get anoher model. I have 5, c330's for over a year and they have had 100% reliability. l
Jan 25, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530
According to technical support, the "glitch" has been fixed with the latest web updater on the Garmin site. In the meantime, you will need to leave the unit unplugged for upto 48 hours to allow the battery die and the unit to get out of its "hang up". Once the battery is completely dead, plug the GPS into a computer (USB) and it should come back to life. Then do the update.
Hope this helps.
Nov 02, 2007 | Garmin StreetPilot c530 GPS Receiver
GPS Logo
55 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
