Question about Acer Aspire One Netbook 8.9" Notebook
My Acer netbook will not boot. It gives me a blue
My Acer netbook will not boot. It gives me a blue screen saying something about a Driver but without a CD to boot from how do you reinstall a driver?
  • 344 Answers
Start up in safe mode (press F8 key at boot) do a system restore back to a time when you know it was working
Posted on Apr 25, 2010
Note book blue screen and report some type of error
This is BSOD short for Blue Screen Of Death, it is usually is a RAM or driver problem. Claim warranty support if available. If your notebook is out of warranty do the following:
Remove the screws that secure the RAM access panel.
Remove the RAM modules and clean the gold fingered connectors with tissue paper.
Now reinstall the modules in the correct orientation. Attention to the cut-out in the module for allignment.
Secure the RAM access cover with the screws and power on.
If it still gives you problems install the graphics driver for your notebook. Visit the Acer website and click their support button. Then select Netbook, then Aspire, then One Netbook, then click confirm. Download and install the graphics driver, latest one only.
Heat is another factor that pertains to BSOD, overheating of the Graphics card, RAM or Processor can also cause this error. Be sure to allow air into your Netbook. Try not to obstruct the intake and exhaust vents.
Take care!
damnor01
Oct 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
My acer aspire one zg5 got the blue screen. after loading the windows, it will stop then flash the blue screen then restart again and again. what will i do? somebody say my netbook needs to reformat. but i...
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Mar 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
My Acer netbook will not boot completely to windows. I get a blue screen and then it attempts to reboot again. What do I do ?
Maybe you can try a system restore. If you are still running the pre-installed OS, press one of the following keys to start system restore. (Depends on which model you have)
  • ALT+F10
  • ALT+F8
  • FN+F8
  • FN+F10
Do this when you see the Acer boot screen. Hope this will help.
Dec 20, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Sep 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One netbook will not boot up
Hi
The laptop is still new and should be under warrenty youre best bet is to take it back and let them repaire it, if you open it youre self and try to fix it you will loose youre warrenty, however if you want to repairityoure self then i would suggest checking out the ram by either inserting a nother set of ram and taking that one out just to test or by using a util like mem test. its odd that it gives you that message but you complain about the sound drivers if it is the case then you will need to get a more updated version of the drivers and install them when you get into windows again. you can also try doing a windows repair
hope this helpes
SlitWrists
Apr 20, 2009 | Acer Aspire 3690-2196 Notebook
How to i recover my acer netbook from a cd if it has no cd drive?
ok you need to insert the disk, then shutdown the laptop then turn it back on, the first screen that shows up should say the brand name and have some words at the bottom of the screen saying press f12 for setup and so on, as soon as this screen appears press the pause button on the keyboard so the screen freezes, now read the options at the bottom and select which ever button opens the boot menu it will be one of the f something buttons, this will open the boot options menu select boot from cd rom drive and that shud start up the recovery program that will guide you step by step. hope that helps
Apr 07, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
475 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
