Question about Microsoft Windows XP Home Edition
Print size I am having difficulty with my print size. My home page is google and when I select something to Print I check the "page" to make sure the text size is set on Largest. However when I print I get this tiny print from who knows where. How do I change the print sizing so it stays at the largest size available. Thanking you in advance
    Sergeant:
    Champion:
  • 427 Answers
When you set the font size, make sure you hit apply and/or save. If this still doesnt work, try compying and pasting to a word document.
Posted on Mar 23, 2008
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
My HP printer prints half on one page and half on another how can i fix it?
Pl share printer model number for better solution.. try this# go to printer menu select default settings..check# check paper size in system..select proper size# un install existing drivers, re install once again..check# print from word or excel format..checkif no result share printer model number... for better solution...Vinay
Mar 30, 2012 | Office Equipment & Supplies
Printer full of ink, but will pring pages either blank of with smeared ink.
Follow these steps to check the print settings for your print job.
  1. In the software program you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Select your product, and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing shortcuts tab.
  4. Under Printing shortcuts , click the type of job you are trying to print.
  5. Review the following options, and then make any necessary changes.
    • Paper size : Make sure that the selected option matches your paper size.
    • Paper type : If one of the options matches your paper type exactly, select that option.
    • Print quality : If you are not satisfied with your printed page quality, or want more densely printed prints, increase the print quality. To print more quickly, or for lighter prints, decrease the print quality.
  6. Click the Features tab.
  7. Check the Print in Grayscale setting
    • If you are trying to print in color, select Color Options , and then make sure that Print in Grayscale is not selected.
    • If you are printing a black and white image, select Print in Grayscale to fix streaking in black areas.
  8. Click OK , and then click OK again to start the print job.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center , then click Settings , then Printer Toolbox .
Select the Services tab.
Click Print PQ (print quality) Diagnostic Page .
Select the Services tab, then click A- Click Align Printheads or
B- Click Clean Printheads .
C- Click Calibrate Linefeed .
If, after repeated printhead cleaning, the Print Quality Diagnostic page shows white lines across the color blocks in Test Pattern 2 (but no white lines in the gray blocks in Test Pattern 3), one or both of the printheads will have to be replaced. The Print Quality Diagnostic page shows which printhead should be replaced.
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Nov 16, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
How to print legal paper in 1210 printer
canon lbp 1210 printers
has a probleam a legal page setting
plese answerer legal page setting
May 11, 2010 | Canon LASER SHOT LBP-3000 Printer
Printing problem
Check your page size. If the page size is sr more than smaller than Letter, the printer will spread the job over more than one page.
Mar 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
When trying to print Avery Labels L7160 the top few labels print within each label 'frame' BUT towards the end of the page the labels are printed further up and therefore are out of the label 'frames' ALSO...
For Word 2007/Word 2010
1- Click on the Office button
2- Select Print then Print again.
3- In the Zoom section make sure 'Scale to paper size' is set to 'A4'
4- Click on the Properties button.
5- Click on the Paper / Quality tab, then click on Advanced.
6- In the Paper/ Output section it has Paper size. To the right you have a drop down menu . Make sure A4 is selected and not letter, then click on OK.
3- There may also be other options in your printing preferences such as 'Print Area', 'Scale to Fit Page Size' or 'Page Margins. These will all need to be set correctly for your design to print 100% e.g. Print Area set to Maximum, Scale to fit Page Size disabled and Page Margins set to Minimized.
Some printers ( for example Epson printers ) have a 'Reduce /Enlarge' facility that defaults to 94% or 97% (instead of 100%). To set this to 100% click the 'Layout' tab and in the 'Reduce/Enlarge' section select 'Custom' you should then be able to change the scaling to 100%.
Mar 12, 2010 | HP LaserJet 3050 All-In-One Printer
Not Printing without Pushing Checked Button
Print a configuration page foung under the information menu of the printer. (Hit the check button, scroll to info menu, hit check button, scroll to print config page, hit check button)
Look at the tray menu area on the page and insure that letter (or the size paper your using) and the type (Plain preferably) is listed for tray 2. Next make sure the tray 1 (manual feed tray) is set to any.
If its not as above, go back into the menu at the printer and scroll down to the "paper handling menu" to set up the trays as above.
Once completed, check to make sure when your printing a document that the size shown on the printdriver side under properies (when you hit file print) says the same.
That should clear any waiting to print issues you have.
For the slow printing issues. Read the configuration page to see what the printer has for memory onboard. If you are using a Jetdirect, addional trys (tray 3 or 4) or duplexing it usually takes more memory. Memory is fairly cheap and can be aquired at www.memory.com for just over wholesale cost.
Hope that helps you.
Jul 28, 2008 | HP LaserJet 2420 Printer
MP760 printing not at 100%
On the Printing Properties/Printing Preferences page, Page Setup tab, check and make sure that 'Normal-size printing' is selected, and that both Page Size and Printer Paper Size are set for the size paper you are using. It sounds like your settings are currently set for Scaled Printing or maybe Poster Printing.
Jun 05, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Can i print the image smaller?
  1. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
  2. In 'Page Size', select the paper size specified in the application. If you select a size that cannot be selected in your printer, a message will display informing you that the setting has been changed to 'Fit-to-page' printing. Select 'Scaled Printing' again.
  3. In 'Orientation', select the same orientation as specified in the application (either Portrait or Landscape).
  4. In 'Printer Paper Size', select the paper size loaded in the printer. In 'Scaling', the magnification at which the document will print so as to fit exactly on the output paper size will appear as a reference value.
  5. In 'Scaling', specify the percentage. You can select from 20% to 400%.
  6. Click 'OK'.
Mar 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma ip4200 printer
1) Under printer options make sure that greyscale is NOT selected. I.E. Color Printing.
2) Make sure page layout is set to 1 (Not 2 per page)
Check margins of page are set to minimum size.
Jan 24, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Microsoft Windows XP Home Edition Logo
164 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
