Question about Carver PM950 Amplifier
My Carver M-1.5t is emitting a rapid pulsing sound on both speakers -- low but annoying. I bought it new in around 1983. Is it fixable?
  • 1 more comment
  • drdavidc May 11, 2010
    Have you added any new electronics ANYWHERE in your home? Anything like a security system, or computer networking? Make sure your amp is properly grounded; if it's on a power strip, try plugging it directly into the outlet.
  • rbrawer May 11, 2010
    Thanks for your reply. I'll try plugging it directly into a socket.
    Ron
  • rbrawer May 23, 2010
    Thanks for the suggestions. No new systems in the house. I tried plugging the amp directly into the wall, same fluttering sound.
  • 185 Answers
This could be related to the power supply it is the
magnetic field variety that has a thyristor controlling its input check if the voltage supply to the amp outputs is varying when the pulsing is heard. if so
the control curcuit could be at fault.
Posted on May 27, 2010
Is it normal for carver power amps to have a slight hum? I have a carver-55x
Hum can come from a jillion different places. Is this hum coming from the unit with no speakers connected, or is it heard through the speakers? What sources are being used? What cables? Are thereany common sources of interference near? Troubleshooting is difficult without much information.
Jan 11, 2015 | Carver Audio Players & Recorders
My pedal is brand new and cuts out after about ten minutes. I also bought the delay pedal and it cuts out around the same time while making a rapid pulsing sound.
This sounds like you MIGHT be running on batteries and they are near depleted... Pedals go through batteries pretty fast. Use power adapters and make SURE to use the right ones as some pedals require different voltages and types of current.
Jul 28, 2011 | Behringer Rv600 Reverb Machine Effects...
We have a buzzing sound coming from the monitor speakers when we go to ANY internet site. It is just loud enough to be annoying!
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Jan 26, 2011 | Samsung SyncMaster 220WM Monitor
Hello! I purchased a pair of M- Audio Av 30 speakers years ago and I've noticed that at times they emit an annoying buzzing sound from the subwoofer parts of each speaker. I normally dont notice it because...
Dec 27, 2010 | M-Audio Studiophile AV 30 Computer...
Sub woofer buzzes all the time, do I have to replace the speaker or can this be repaired?
ur sub wont buzz due to bad speaker. either u have a faulty preamp or power amp. yes it can be repaired and will not cost much. if it is loud and annoying, get it repaired. sometimes subs emit low hum when powered up. this is the way the are desinged.
Apr 13, 2010 | Kenwood SW-306 Speaker
My turntable connect to Carver Preamp, I bought a
If you can hear music with the volume up, but like it was turned down low (from the power amp), then yes there is something up with it. If it's the same on both left & right channels, then it's something common to both. For instance the power supply, or an IC that has both channels going in it.
If however the power amp does produce sound normally with another device, then either the turntable has a fault, or the pre-amp has, perhaps on the pre-amp inside it for the cartridge.
Dec 16, 2009 | Yamaha P-2500 Amplifier
I have just bought a new bose 901 speaker system which included equalizer. I am not sure how to connect the equalizer to my receiver Denon 3808. I need help.
http://products.bose.com/pdf/customer_service/owners/901_guide.pdf
Be advised, this speaker system requires its own dedicated two channels of signal preamplification and power amplification and the required Active EQ is not to be used in the signal path of anything else. I have them as my Main Left and Right Speakers in a 7.1 set-up, but I'm using a 5-channel external Carver Power Amp to drive them, a sSb and the Rear Surrounds. The Active EQ is between the Receiver's Main L&R Preamp Outputs and the two Carver Amp channels that drive the 901's. Don't think you can just add the 901's into your living room and enjoy multichannel sound. Search around fixya, I have written extensively on this subject.
Nov 18, 2009 | Bose 901 VI Main / Stereo Speaker
Right channel cutting out.
connect right channel speakers to amp left out if the problem fixed you will have a problem in amp itself.
if the problem remained you will have a problem in speaker itself test first with new cable and second with speaker cabinet,
Apr 14, 2009 | Audio Players & Recorders
Sound is Pulsating when music plays
Ahh, I have these speakers and its common when you have the volume knob turned all the way down, to fix it, turn the volume REALLY low in windows, so that way you have to turn the volume knob on the speaker control up to 50-100%. And you will have better sound..... No pulsing
Oct 02, 2008 | Logitech X-540 Computer Speakers
251 people viewed this question
Top Carver Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
jeff5may32
Are you a Carver Audio Player and Recorder Expert? Answer questions, earn points and help others
