Cannot get hold to work keeps dropping from 72 to 60
  • 821 Answers
Hello,please kindly rephrase the question,what is dropping from 72 to 60?
take care.
Posted on Apr 25, 2010
Why does the front roller keep dropping, resulting in lawn scalpage?
Is the adjuster broken or wore out so it won't hold where it is suppose too be. Some times you just need to tighten the bolts that holds them on. You may have to replace the adjuster as well.
Jul 27, 2015 | Garden
Sony walkman volume
spray 90% rubbing alcohol from a spray bottle into the volume button area push the button reapeatedly or, turn the knob back and forth then: let it dry for about an hour then try to use it the control should be clean and working again.
Dec 03, 2013 | Audio Players & Recorders
How to keep new exhaust o rings from falling out while putting the pipe back on fzr 600
Use just a couple of drops of super glue. It holds the rings and then the heat from the exhaust destroys the glue. Works perfect! Please rate my answer. Thanks.
Jun 01, 2011 | Yamaha FZR 600 Motorcycles
Garmin 2720 keeps dropping the satellite connection
Turn unit off hold down menu button while turning unit on and, hold button down till a white page comes up that says general.
This this the testing mode if it is not testing then press the menu button, after test is down press menu button a couple of times and it will go to another testing, continue to the end turn power off then back on and should work.
May 26, 2010 | Garmin StreetPilot 2720 GPS Receiver
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
Calls keep dropping
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Apple iPhone Smartphone
HTC Touch -- Drops Connection to cell tower
I find the HTC touch drops many more calls than other phones I've had. Just doesn't seem to be able to hold a weak signal very well. On my way home from work, I had 2 places where I dropped calls. When I got the HTC Touch, I now have about 4 or 5 places where I lose calls. One additional place is sitting at my desk at work. Very frustrating!
Nov 04, 2008 | HTC Touch P3450 Smartphone
Toyota window one touch
The switch may need "reinitialized". Turn the key on. Press & hold the one-touch in the down position, after the window lowers, keep holding the switch down for 10 seconds. Then, pull up on the switch and hold it 10 seconds after the window reaches the top. This is the renitialize proceedue.
If this does not work, try lubricating the window run rubbers with silicone spray.
Sep 13, 2008 | 2002 Toyota Land Cruiser
I dropped it
try this:
take the battery out, hold the on/off switch to the left and keep it, then put the battery back in and THEN release the switch...with some luck, if its harddisk survived the drop, you will be able to get into the system-menu and reset it...
or:
let the battery in and hold the switch to the left for some more time..
Mar 16, 2007 | Creative Labs Zen Micro MP3 Player
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
