Question about Singer Touch Sew 7462 Mechanical Sewing Machine
Fixing the bottom thread when it sews loose
How do i fix my sewing machine when the bottom thread sews loose?i can only take out the bobbin itself and i don't see any screws to tighten, and tightening the tension doesn't work either...
    Genius:
  • 1,116 Answers
It could be that you threaded the machine with presser foot down.
When the foot is down, then tension control is closed and the thread cannot seat for proper control to the needle.
What appears to be a bobbin problem is actually the top thread not having the tension needed (thead is not where it should be within the tension control) to form a stitch.
Posted on Apr 25, 2010
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 139 Answers
SOURCE: my singer touch & sew has a problem with
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 16, 2010
SOURCE: I cannot tighten the bobbin
the screw on the bobbin case---turning the screw to the left tightens
turning the screw to the right loosens
Posted on Sep 28, 2010
  • 92 Answers
SOURCE: Sewing 1/4" leather. Bottom thread
You did it backwards!!! Reset the bottom tension to the default position, with heavy threads its touchy to get back to normal. Turn the upper tension about 1 turn clockwise (tighter) and try. No luck, try a turn then test, then a turn, test.....The size of the thread can cause issues as well. We mostly use #69 nylon threads, but the 1541 can use # 69 to 192 without to many problems. look in the book for how to reset the bobbin case tensions. The 1541 is a wonderful machine, much better quality than the chinese junk being sold nowadays.
Derek
Posted on Jan 15, 2011
Testimonial: "Thank you very much. Bev"
Tally Girl
  • 1133 Answers
SOURCE: I am sewing outdoor fabric
Probably a little heavy duty for a domestic machine - most don't like thread through the bobbin tension device any heavier than 50 grade.
Some tension devices have a hole that you can use to bypass the tension spring (Elna is one) which allows thread like perle cotton to be used in the bobbin. But you still can't put it through the needle (just on the underside for decorative sewing effects) .
In the past I've needed to sew vinyl tractor seats where I was stitching the vinyl to a 1/4" thick foam and after trying everything (roller foot, leather needle) on the domestic machine, I bought a Singer 20U industrial machine with 1 1/2 hp motor in a table in order to seam this weight of textile. Different system needle used and the bobbin could handle heavier weight thread.
Probably not the response you wanted though.
Posted on May 05, 2011
Husqvarna designer se / bottom tension loose
If the bobbin thread is simply laying on the surface of the fabric, you need to increase the top tension. The tension is correct when the bobbin and top threads meet in the middle of the fabric.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 16, 2017 | Husqvarna Sewing Machines
When I finish to sew the end of string does not lacks it self and when you pull the bottom of the string everything opens
If the upper thread is looping on the bottom of the fabric as you sew, the upper tension is too loose. It could be threaded incorrectly, the upper thread may not be seated in the tension disk properly (be sure to RAISE the presser foot BEFORE threading the upper thread), or the upper thread tension is set too loose.
If you have checked everything and it is still looping underneath, the bobbin tension may be too loose or the bobbincase needs replacement.
Sewing Machine Thread Bunching Up Here Why
Oh You Crafty Gal Sewing Lesson 10 How to Fix Tension on Your Sewing...
Dec 20, 2015 | Janome Sewing Machines
The bottom thread in my sewing is looping and baggy.
Hello, If the thread is loose on the bottom then it is the tension on the top. If the thread is loose on top then it is underneath.
Dec 11, 2014 | Sewing Machines
Loose bobbin tension
the bobbin tension is set by that small spring plate that you pull the thread under after you put the bobbin back in the carrier / holder
a very small turn of that screw makes a big difference ob the tension unlike the needle thread tension
mostly the problem ( you never bothered to mention the symptom ) is bird nesting under the fabric which is the needle thread tension not tight enough
Jul 06, 2017 | Brother SE-270D Computerized Sewing...
My Brother vx-800 is sewing the top thread into the machine, how can I fix it?
try changing the needle
clean under the needle plate & in bobbin area for lint or loose threads
take the bobbin out & re-insert the bobbin in to the bobbin case
if these suggestions don't work then it would be a good idea to have the machine checked
Apr 01, 2012 | Brother CS-8150 Computerized Sewing...
I have a problem ajusting the bobbin thread. I have a Janome HF107 the bottom thread is so loose it just pulls right out. How do I fix this
Make sure the bobbin turns anti clockwise, adjust the screw on the bobbin case about a quarter of a turn to the right to tighten then test sew, repeat if necessary
Aug 12, 2011 | Janome 6019QC Mechanical Sewing Machine
972 Mechanical Sewing Machine: I have a problem with Singer 972 sewing machine. T...
Always thread a sewing machine with the presser foot up and this will eliminate what looks like a loopy bobbin thread.
If you thread with the presser foot down, the tension control is not open to accept the thread as it is designed to do.
Then when you sew, the tension cannot control the top thread and the bobbin thread pulls the loose top thread to the bottom of the fabric.
Normal setting for the tension is usually mid-range ( 4 or 5).
May 07, 2010 | White Sewing 972 Mechanical Sewing Machine
Bobbin thread is loose what can I do to fix this problem?
make sure that the needle is correct inserted correctly, then check the threading as it will be the top that is wrong not the bobbin. cheers
Nov 20, 2009 | Brother LS-2125 Mechanical Sewing Machine
I have rewound a bobbin on my sewpro sewing machine. When I loaded the bobbin back in the machine I can't get the machine to pick up the thread to sew again.
Welcome to FixYa. I always try the easiest fixes first - make sure your bobbin is inserted correctly, and that the bobbin thread is securely threaded in the bobbin case (sometimes the bobbin thread doesn't "catch" when you place it in the bobbin case). If all is well in the bobbin area, rethread your machine. Make sure that the presser foot is in the raised position when you thread. If it still isn't sewing correctly, change your needle. These last three steps fix most problems. But, if you are still having problems, look at the thread in the problem bobbin. It should be straight and tight. If it is kind of wobbly and a little loose, you'll need to wind the thread onto a new bobbin.
If are new to sewing, keep your manual close by and refer to it often. Simple mistakes can make a new sewer loose confidence, but it is all part of the process of learning your machine.
Good luck and happy sewing. If you have a sec, please rate my response so I know when I need to work on my responses.
Thanks for stopping in. Ginny
Jan 28, 2009 | Sew Pro QuickStitch SP-402 Mechanical...
Bobbin on a Viking #1+ sewing machine
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Jun 19, 2017 | Husqvarna Viking 1
Singer Touch  Sew 7462 Mechanical Sewing Machine Logo
171 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
