Question about BenQ FP737S-D 17" LCD Monitor
Benq 17"Lcd monitor fault
Benq17"lcd monitor
Computer running with valid output. Turn on lcd, no benq logo, bands of moving horizontal and vertical lines appear for about 3
seconds. Screen then goes blank. Lcd light stays blue to indicate video present. Suspect video input controller pcb rather than video panel electronics. Lcd does the same thing each time. What do you think.
  • snj4ever Jun 10, 2008
    on start up monitor is black if you turn it off and bang it most times will go again. i have two of these 17 inch benqs and they both do the same thing FP71E
    Champion:
  • 220 Answers
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Posted on Mar 24, 2008
  • Samir  Shah
    Samir Shah Mar 24, 2008
    First remove the Computer input.It should show BenQ logo at startup and then "No signal cable connected".If not it's a monitor problem.
    Samir
BenQ Q24W5 LCD monitor circuit diagram
HI.............
Repairing BenQ 17′ LCD Monitor
I came across a common fault problem in BenQ 17′ LCD Monitor. The problem is have power but no display. Once you has opened the LCD cover, check the pico fuse for open circuit (very common), the push pull transistors C5707 for short circuit and the Buck royer circuit p-channel fet FQU11P06 also for short circuit too. For your information, if you can't get the FQU11p06 you can always use FU9024N as a replacement. Resolder all the high voltage transformer pins and replace the components above and I'm sure you will bring back the life of this BenQ 17′ LCD Monitor.
You may go to this fairchild semiconductor website to download the spec of the FQU11P06 P-channel FET.
http://www.fairchildsemi.com/ds/FQ/FQU11P06.pdf
GOOD LUCK.............
Sep 23, 2011 | Computers & Internet
Repair BenQ Q24W5 monitor
HIIIIIIIII...................
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
Please help me fix this benq monitor
There are many posts that have solved this. Check em out
Oct 09, 2008 | BenQ FP71G 17" LCD Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Power but no picture
bad capacitors or power board in the monitor
May 10, 2008 | BenQ FP731 17" LCD Monitor
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Apr 16, 2008 | MPC Computers AOC 7F 17" CRT Monitor
Benq monitor flashes off and on
It has a large capactor inside that is leaky, needs changing. In powersupply.
Sep 14, 2007 | BenQ FP737S-D 17" LCD Monitor
Benq FP731 17" monitor goes Blank after start up
Change the 2SC5707 transistors and electrolytic caps in the inverter
section. Also check the 3A picofuse, and resolder all transformer
pins
Aug 09, 2007 | BenQ FP731 - 17" LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
484 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
