Question about Refrigerators
I have ice buildup in the freezer which is leaking into the refrigerator. I have a Whirlpool model ET8CHMXKB05
    Scholar:
  • 126 Answers
YOUR DEFROST DRAIN IS CLOGGED IN YOUR FREEZER. UNPLUG UNIT. REMOVE BACK WALL OF FREEZER. REMOVE FREEZER FLOOR SOME DO NOT COME OUT. REMOVE ALL ICE. IN THE DRAIN TROFF USE WARM WATER OR HAIR DRYER. KEEP FREEZER 0-6 DEGREES. IF PROBLEM REOCCURS THERE IS A HET PROBE TO KEEP DRAIN HOLE CLEAR. PART NUMBER 819043
Posted on Apr 25, 2010
I have a whirlpool refrigerator model m#EB9FVBRWS05 and the water leaks from freezer, freezer not defrosting and frost buildup . How do I fix this problem?
There are three main components in a defrost circuit, the heater, the thermostat and the control device(either a timer or and ADC board). One of these are not working.
Dec 24, 2015 | Whirlpool Refrigerators
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
My whirlpool bottom freezer is leaking water my model is EB9FVBLWS04
Here is a=> EB9FVBLWS04 Parts Manual Go to page 3 and you will see item location 11 You may need to move some of the rack or drawer hardware on one side of the freezer liner to be able to remove item 11 in that photo on page 3 of the parts diagram before you are able to get to the drain opening very well. Here is more at this link Leaking Refrigerators. After removing the ice from the opening you will still need to force something through the drain to cause the blockage to be broken loose to prevent what causes the water and ice buildup. I am here should you have questions, Thanks Sea Breeze
User Manual HERE
Jun 23, 2013 | Whirlpool Refrigerators
My Whirlpool bottom-freezer, french-door refrigerator is 3 years old. All the lights work fine, as does the ice-maker, and the main compartment cools as it should. The problem is: the compressor motor...
Newer model refrigerators run a lot more than older ones but you could have leaks around gaskets, check freezer compartment and see if there ice buildup around door if so let this defrost by turning off if possible. The defrost circuit should take care of this but sometimes in very humid weather it does not.
Aug 02, 2017 | Whirlpool GI5FSAXV Bottom Freezer French...
Whirlpool fridge model # ed2fhgxkt04, ser # sm4434895. I am getting ice buildup in bottem of freezer. no ice on food or sides of freezer. where is defrost drain located to clear and or defrost it?
First off, if you get in a hurry, you can cause serious damage.
The machine must be unplugged, and allowed to completely defrost.
24 hours would be considered normal, but you can quicken that up some by placing a floor fan in front of the freezer compartment with the freezer door left open.
You can access the drain hose by removing the rear access panel.
Service techs then use compressed air connected to a hose and insert it in the end of the drain hose, and, BLOW AIR THRU IT GENTLY.
2 causes for this problem. one, the drain was in fact plugged up. Two, if the machine has an icemaker, the fill hose from the water valve to the ice maker is leaking, causing water to leak and then freeze in the bottom of the freezer.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My whirlpool refrigerator (Model ET18DK) was moved downstairs a few months ago. The top freezer and the refrigerator only cool a little bit now. The freezer is about the temp that the refrigerator should...
check for:
  •  any ice or frost buildup in the freezer (defrost problem)
  • airflow restrictions, like dirty coils or if the refrigerator is on carpet.
  • it could also be a weak compressor.
let me know Mike
Aug 08, 2008 | Whirlpool Refrigerators
Refrigerators Logo
394 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
