Question about Coffee Makers & Espresso Machines
Bennoti expresso machine-will not dispense coffee. The steamy water does dispense behind the casing straight into the drip basket. Never used this--was brand new from sealed box. I thoroughly cleaned the spout to ensure it was not blocked.
z34aga
  • 137 Answers
SOURCE: Water in the drip tray of coffee machine
take out the mecanism and clean it how is instructed in manual, than get it back carefuly. Pay attention on position of mecanizm.
Posted on Mar 28, 2009
  • 13 Answers
SOURCE: Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
Posted on Jul 08, 2009
  • 3 Answers
SOURCE: Rio Vapore Problem
The nozzle could be clogged. You may wish to take it apart and I bet its clogged with calcium deposits.
Posted on Feb 10, 2010
  • 17 Answers
SOURCE: Hi, I have an XP7240 and recently i only half a
I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. It's a lot of work but if you're handy you can get to the valve on the bottom of the machine. I have the same problem but haven't looked up the replacement part (can be expensive). Good luck!
Posted on Aug 07, 2010
  • 232 Answers
SOURCE: I have the Krups 964
I don't know much about this unit, but there might be a rubber seal in head where the porta filter locks in to. It is possible that this seal is either damaged or just corrupted with grounds. Try cleaning it out and or checking the seal for damage.
Posted on Sep 10, 2011
Expresso is too large
Nancy, this setting is controlled by the settings menu. You reach that by right arrowing through the different beverages/menu selections until you select "Settings".
  • In settings, scroll to "program the amount"
  • place a cup under the spout
  • select the beverage you want to program, espresso in this case
  • select start
  • select okay when the amount of water has been used
  • the machine will remember this setting for future espressos
  • the same menu structure allows you to control the amount of coffee ground, as well as the amounts for other beverages
Mar 15, 2016 | Miele CVA 4066 Stainless Steel
How to get less water dispensed. My expresso dispenses 100ml. Too much for an expresso. Help.
On a lot of machines if you press and hold the button while it dispenses and release the button only when you have the desired amount it will retain that amount for the next button press of that particular button.
Jul 23, 2014 | Saeco Incanto Classic Fully Automatic...
When I just have water in the portafilter it runs through fine. When I put the expresso in it clogs and expresso will not flow through.
No solution here. Utopia directions say to only use MEDIUM (drip) grind. Ain't it awful? I prefer ultra fine grind, frankly muddy coffee.Deb
Jul 10, 2011 | Starbucks Barista Utopia
We got a gagia expresso color machine recently. We used it for a week and now the machine is not is not dispensing expresso. The machine makes sound but no expresso comes out. The tank has enough water....
Your are propably need to prime the machine. This mean that air blocked in the machine and need to get out and fill all pipe system with water.
To do this you need to warm up the machine and turn the hot water knob so you will get one cup of hot water from the steam wand. After that try to get some water from the coffee head without any coffee in the filter handle. Now the machine is ready for coffee again. You will need to prime the machine very often so try to remember the procedure. This will happen again usually after you use the steam process and this normal for your machine.
http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime
May 01, 2011 | Gaggia 102534 Espresso-Color...
The water drips out excessively at the top, there is asecond hole where it comes out
When this happened to me, I found that the filter basket had worn and wasn't lining up to catch all the water from the bypass line. I used a small rubber rod behind the lower connector post (where it attaches the basket to the coffee maker) and that forced the top of the basket back far enough to catch all the water. I am using that until I can find a replacement basket.
Aug 05, 2010 | DeLonghi Caffe Nabucco BCO70...
Very little water is dripping into the carafe
Try to run vinegar undiluted through the coffee maker first. If this does not help, you may have a plugged valve in the coffee maker or a tube/hole where the coffee maker water should drip through. if this coffee maker has a dispenser(where you put your cup against it and the coffee comes out) then there is likely a plugged up valve. This will require dismantling the coffee maker to clean it. Usually coffee makers get plugged up because coffee leaves a residue that requires scrubbing at time to remove.
May 26, 2010 | Dualit Expresso + Filter Espresso & Coffee...
Drip tray is filling up with water sooner than in
Hi
Either your grind is very coarse or your injector seal is bad. The injector is behind the brew unit and has 2 orange O-rings on it. See if you can wiggle the injector?
Dec 31, 2009 | Solis Master 5000 Espresso Machine
Water/grinds spillover in coffee basket
Pot must be inserted with the handle pointing straight out the front so it will hit the valve that is below the basket designed for the "rob a cup" while brewing feature.
Calvin
Aug 13, 2008 | Coleman 5008C700 Camping Coffee Maker Free
CONSTANT LEAK PROBLEM How can we stop the coffeemaker from leaking? Our coffeemaker is 6 months old. Three days ago it developed the problem of the coffee constantly leaking through the normal dispense...
Try using straight vinger through the complete cycle then run plain water through the cycle see if that helps. It helps to clean the machine.
Jul 22, 2007 | Cuisinart DCC-2000
Coffee Makers & Espresso Machines Logo
73 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
