Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
I had to take the motor out and put it back together now its not getting water what do I have to do. The motor works fine
  • 990 Answers
If this is a self priming pump you will just have to fill the pot with water. If not you will have to open a valve and force some water through the system to prime the pump. This being done, if you still have no water you may have a suction leak keeping the pump from priming and may need a repairman at that point. Good luck.
Posted on Apr 25, 2010
The brushes are not working.
We have a Max Extract 60 and when we turned it on the brushes did not work. My husband took the pieces for the brush motor apart and put it back together and then they worked fine. They must of been bound up or put together wrong. Works great now.
Dec 21, 2010 | Hoover F6055-900 SteamVac Maxextract LS...
Drum isn't turning but the drive belt is ok. taking in water and draining water fine.
the coupling on the motor ia broke you have to take the front off the washer and take the pump off there are clips you have to take off pull the motor out and the rubber coupling is right you will have to buy another coupling they cost about $10.00 then you put it back together. Tommy
Jul 17, 2009 | Washing Machines
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
When we press the "on" switch in or Kohler whirlpool tub it trips the wall switch. I changed the wall plug and it still trips when trying to turn it on. It has always worked fine. Any suggestions..
Remove the GFCI WALL OUTLET and try connecting those wires together blk/blk..wht 2 wht...ground to ground and then see if tub will stay on, if not suggest put back together and call qulified whirl pool tech to find short in pump motor.
Please rate. Thank you. jj505
Mar 28, 2009 | Kohler Synchrony K-1192-LH-0 White 5 Feet...
Braun 4501 shaver non-function...
You might try the original type battery (rechargable) Batteries Plus has them for less than 3 dollars, and they will solder the leads to the battery FREE! If you were lucky enought to get the 4501 apart, you may have problems getting it back together. Be sure front and back panels are free from the sides and it wont go back together unless you put the TOP snaps in first. Good luck...I got mine going for $ 2.78...
Feb 07, 2009 | Braun 4501 Electric Shaver
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Whirlpool washer won't drain
this machine has the pump directly atached to the pump assy, so if the motor is runnning your pump will drain water. more likely is that when you put the unit back together perhaps you didnt plug the lid switch assembly bak in. if there is no lid switch detected the unit will not drain or spin and when it gets to that mode it will simply stall out. no noise or anything. will fill, agitate but not spin and/or drain/ check the lid switch!
Nov 11, 2008 | Whirlpool Ultimate Care II GSQ9669L Top...
Open Questions:
See all Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Questions
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
241 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
