Question about Price Pfister Single Lever Handle Faucet CHROME
How to remove single lever handle does it require a spceial tool, because an allen wrech doesn't work
  • 349 Answers
Most faucets have allen screws holding handle on or it may be recessed back in handle or if it is striped out may need to get a bolt extracter you can get them at hardware store pretty cheap.
Posted on May 05, 2010
Lav center set faucet handle removal model K10271
The handle may be secured with a set screw in the body of the handle that must be loosened before the handle will lift off the valve - the set screw will require an appropriately-sized hex (or "allen") wrench. If you cannot find a set screw on the handle, then the handle is friction fit - in which case no tools are required, just a bit of force to lift the handle off.
Hope this helps. Post a reply if you need further assistance.
DIYpro
May 17, 2011 | Kohler K-10270-4A-G Forte Centerset...
Lever won't stay on at low flow rate; lever closes automatically. What can I do to fix it?
Sounds like the retaining ring under the handle may need to tighten a little to stiffen lever a little. To remove handle take plastic red/blue cap at base of lever covering the screw. Remove allen screw that holds handle to base with a allen wrench.
Try to tighten collar that holds the stem for the lever and that should help with the lever. if not the gasket that's under the collar maybe wore to the point that tightening want effect it.
If you need a parts diagram go to this link for an exploded view of the internal parts. I hope this will be helpful to you.
http://www.needplumbingsupplies.com/Danze/Specs/D403412_Inst.pdf page 4 has a breakdown.
Dec 29, 2010 | Danze D403412 Melrose Single Handle...
I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
How do you tighten or remove handle on a danze shower faucet
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
Jul 02, 2010 | Danze & Single Handle Tub And Shower...
How do you switch out the single lever dial on a delta shower fau
Hidden under the lever is a little hex screw. Use an appropriate hex a.k.a. "Allen" wrench to remove the handle. You might want to shut down the water service first to save your shower until later.
Mar 16, 2010 | Delta & Single Handle Shower Faucet
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle shower faucet, contstanly drips
Moen single handle - push pull has a screw beneath the handle cover plate. The Moen single lever handle has an allen wrench screw located under the curve of the handle. Once either one of these screws are removed, the handle should come off easily.
Once the handle is off, the water must be turned off and then you can remove the cartridge. Some cartridges are difficult to remove and may require a special tool. Most new cartridge packages have information on them to explain how to remove the cartridge.
Mar 12, 2009 | Home
WHEN FAAUCET COMPETE SHUT DOWN AND STILL LEAKING
Delta Single lever? Remove handle by loosing the allen screw . Tighten the spanner clockwise. If that doesn not fix problem, turn water off, remove spanner nut. Remove whole assembly. Take to plubming supply and latch us for rebuild kit.(two rubbers, two springs,. a spanner wrenchand an allen wrirenc and maybe a new spaner nut) Install same.
Mar 10, 2009 | Plumbing
Leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
Dec 30, 2008 | Danze D403412 Melrose Single Handle...
Price Pfister Single Lever Handle Faucet CHROME Logo
268 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
