All of a sudden, I have begun hearing a clicking "sound" from my Dell Computer Speakers. What is the cause and how can I stop that from happening?
There are a few simple things to check first:
Make sure your computer has a sound card.
You must be logged on as an administrator to perform these steps.
Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Expand the Sound, video and game controllers category. If a sound card is listed, you have one installed. If no sound card is listed, You will need to install one. See Install or remove a sound card.
If there is a yellow question mark next to
the name of the sound card, there might be a problem. Right-click the
name of the sound card, and then click Properties.
Click the General tab, and then look in the Device status box to identify problems with the sound card.
Make sure your speakers are plugged into a working power source and turned on.
Make sure your speakers are correctly connected to the computer.
On your speakers, find the cable that plugs
into your computer. Make sure that the speaker cable is plugged into the
speakers and the correct jack on the computer. For example, if the
cable is a 1/8 inch cable, there should be a round jack for it on the
back of the computer. If it is a universal serial bus (USB) cable, it
will plug into any USB port on your computer.
Make sure that the speaker volume is not muted or turned down too low.
Open Volume Control by clicking the Start button , clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
Under Main Volume, move the slider up or down to raise or lower the volume.
Some mobile PCs have an external volume
control on the outside of the case. If you're using a mobile PC, check
the external volume control.
Make sure your headphones are not plugged into
the line out (headphone) jack of your sound card or computer (unless
you want to be listening with headphones rather than speakers). When you
plug in headphones, most computers automatically cut the sound to the
speakers.
If those are desktop speakers check with the wiring and earthing of the speakers.If the connections are proper, in that case you can try re-installing the Audio Drivers for your computer.
