Question about Homelite Mighty Lite Lawn Trimmer
How to replace fuel line on a homelite mighty lite 26cs grass trimmer?
SOURCE: Brand new Homelite Mighty Lite 26cs String Trimmer
carb setting is too lean,need special tool to open,go to mower shop.This model also has problems with starter mechanism,I hope you have a warranty
Posted on Jun 14, 2009
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
SOURCE: How do I feed string into my Homelite Mighty Lite
cut a 6 ft piece and wind it (starting with the middle of the trim line) around the head with each head going opposite directions. When you get it wound up, you will have two pieces sticking out in opposite directions and they can be clipped into the small plastic slots on the edge of the string canister. THen press the ball on, and attach to the trimmer.. Just keep the string the grooves and you will be fine...
OHYEAH!!! dont worry if it keeps coming unwound or pops off the trimmer at first, it will happen until you develop the technique needed for a quick replacement
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Posted on Jun 03, 2010
Testimonial: "Thank you! Your response helped me troubleshoot."
goldenglove1
  • 144 Answers
SOURCE: Replace a primer bulb on a Homelite Mighty Lite
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Posted on Aug 12, 2010
  • 3 Answers
SOURCE: Trimmers: Homelite Easy Reach-25cc-Model #
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Posted on Sep 08, 2010
I need an address to purchase a fuel tank for my mighty lite 26cs . Model - UT21506 SN- ATK0712739
Go to psep.biz or jackssmallengines.com you will find all that you are looking for ! Godd Luck...
Aug 16, 2011 | Homelite Mighty Lite Lawn Trimmer
How do I get the head off model 26cs
Here is a link to your instruction/owner's manual. It will have the directions inside. Go to:
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/ut21967.html
Jun 04, 2011 | Homelite Mighty Lite Lawn Trimmer
How do you restring grass trimmer model 26cs
Go to smalleng.com or check out you tube it's amazing the tutorials you can find. Good Luck...
May 28, 2011 | Homelite Mighty Lite Lawn Trimmer
Cracked fuel line
you can get many sizes of hose at the home depot
May 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Hello I need the homeleit 26cs mighty lite manual, the starting coard wont retract
This would be caused by the starter pulley separating and jamming on the flywheel, In most cases it would cost more to fix these machines than it would be to replace them. Unless of course its under warranty then just take it back for a repacement.
Aug 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
167 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
