Question about Poulan "Poulan" Push Mower
My weed eater 500 series mower is not getting gas. It runs if I pump the primer but stalls after that gas is burned. Why am I not getting gas?
  • 160 Answers
First possibility: The in-tank filter may be clogged...The fuel line running into the tank ends at a small canister bulb, basically a cage made of screens to filter debris that builds up in every tank...as the filter clogs, only manually pumping the fuel with draw enough to feed the engine.
Make a small hook on the end of a piece of wire ( 8" of coat hanger) and reach into the empty tank to gently pull the filter to the fuel port for removal and cleaning.
* Don't smoke! An empty tank is just as explosive, if not more so, as a full one.
** The inner line is a bit short, and will disappear back inside after removing the filter (and it's a pain to get back), so pinch or loose-wrap the wire onto the line to keep it outside until you're ready to replace the filter.
Second possibility: The problem could just as well be a lack of air as fuel...pull the air filter cover and filter, but replace the bolt a few threads to keep it in place.
After cleaning the tank filter, and refilling the tank, add a few drops (about a teaspoon) of gas into the throat and give it a pull or two.
Once it warms up, shut it off so that you can clean and replace the air filter and button it down.
*** Adding a tsp of Marvel Mystery oil to the tank will finish cleaning the lines and ports...I love the stuff; Works better than most, and it's the best deal in fuel system cleaners.
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 25, 2010
Murray weed eater won't stay running
have to go further in the carb, If you left 'todays' ethanol gas in the weed eater for more then a few months, it probably messed up the Carb. Ethanol gas is very bad for carburators on any machine
Aug 31, 2015 | Garden
Does the 500 series has a fuel filter. It runs for a few seconds with the gas I feed manualy and then dies.Is it the filter and where is located? Model # 961140015 02, serial # 032910M 040495.
Could be the filter if there is one but try this as well.Check the fuel jet in the fuel bowl as it sounds like the jet could be partially plugged and not letting the gas come into the carb fast enough. Clean the fuel bowl out and blow the jet out and make sure the holes are not dirty. Make sure the gasket on the bowl is installed properly when you are done.
Sep 27, 2014 | Garden
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Repair weed eater
If you see gas in the primer bulb it is pulling in gas to the bulb. If not check for cracks in the bulb assembly and check to see if the fuel lines are not off their fittings and not cracked.
Jul 17, 2013 | Garden
How do you check the oil in a Weed-Eater-500-Series Side Discharge Mower, Model 10854261. It has a basic Briggs Stratton engine. I have a lost the manual and cannot figure it out!! HELP!!!!
most mowers have a dip stick like a car and the oil should be changed often and acting as if it wants to stall try fresh fuel gas is only good for 30 days in small engines
Mar 27, 2012 | Briggs & Stratton Garden
GBI 20 Weed Eater Blower ran out of gas and will not restart What to do to restart?
somewhere on it is a primer button pump it a few times and choke the blower it should start
Sep 18, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I I need the little plastic gas plunger for a Poulan Featherlite Plus weed eater
The part is called a primer bulb if it is mounted on the carburator or if it is a remote primer it is called a primer pump. Check with a full service dealer in your area if you have one. If you
can not find one in your area contact southern supply company at
205-833-2525 or email them at southern.supply@mindspring.com
and I feel sure Jason or someone there can help you.
Sep 13, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Can,t prime fuel with primer ball on my weed eater XT 400, lots of fuel and lines look good
be sure the line in the tank did not disconnect. that would cause you to pump all you want but never get a drop.
Jul 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan "Poulan" Push Mower Logo
2,167 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
