Question about Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267
106.9547610 Kenmore SIde by Side not cool
106.9547610 Kenmore SIde by Side 1994 not cold at all on freezer/refrigerator side. No frost on evap coil. No evap or cond fan, and no compressor hum. Lights work on/off.
  • 4 more comments
  • lnxcthlc Apr 25, 2010
    Where is the Control Board?
    Sorry to be a bother, but I see nothing but a compressor, cond fan/motor and some other things that would not lead me to believe they are "control boards"in the back bottom area. There is a Main harness plug going in under the fridge at the bottom freezer side. It appears to have a flush mounted metal panel next to it, with no apparent way for opening. Could that be it?
    Also, could you mean Defrost Timer Circuit Board? This is located behind the user control panel in the fridge.
    The model number I put is is from a Side by Side, but I am pretty sure it is a 27 cubic Foot instead of the 21.7 that I see listed.
    Anyway. I tested for power at the Defrost Timer Circuit Board and I do not have power at either of the 6 connectors on it. To provide more info, this is not a mechanical timer unit and it has a peculiarly shaped relay on it.
    I do have 120v power at one of the Connections (my bad) on the Defrost Timer and 8.46v at another connection. Is there anybody with experience on these old Whirlpools/Kenmores?
    Please tell me how you came to that solution. I am fairly technical, so I could understand most of the details. Is there a point on the compressor itself that I could check with a multimeter, or a relay or a switch that would give me an indication as to why the fans would not be blowing?
  • lnxcthlc Apr 27, 2010
    It worked. Jumping the black and orange wires started the fridge right up. Thanks a bunch! I will order that part and hopefully get a few more years out of it.
    President:
  • 949 Answers
It looks like you have been having a long conversation about your no cool refrigerator, would you like me to step in an assist or step back and allow the previous tech to continue?
Posted on Apr 26, 2010
  • Philip Apr 26, 2010
    I cannot see what advise you have been given so far, but I can see what you have written and I am going to take a shot in the dark here.
    It sounds like you know how to read a meter and you do not have any fans running or the compressor running.
    Looking at the wiring diagram for your refrigerator you should have 120 volts from the black wire (terminal 1) to the white wire (terminal 6) on the defrost control which is located in the upper console of the fresh food section. Check from the orange wire (Terminal 4) to the white wire (terminal 6). You should get 120 volts, if you do have it for the first check and not the second check then the defrost control is bad. You can verify this by carefully jumping across 1 to 4 (Black to Orange) and the motors and compressor should start.
    If the voltages there are fine there follow the orange wire to the cold control, you should have 120 volts from the orange wire on the cold control to the white wire. You should also have 120 volts on the red wire to white this is with the cold control turned on. If you do have it at the orange wire but not the red then the cold control is bad. The red wire then splits off into 3 parallel circuits feeding the 2 fans and the compressor.
    Let me know if you want more information.
  • Philip Apr 27, 2010
    That is fantastic! Thanks for using FixYa
    President:
  • 2,030 Answers
Sounds very much like your compressor has gone bad.
Posted on Apr 25, 2010
  • 821 Answers
Hello,the compressor is not producing gas that is the problem or probably you need a gas refill into your refrigerator.you can also check if the defrost timer is not stuck.but the actual problem is the compressor,this has to be changed or serviced.
thanks for using fixya,
take care.
  • 1,284 Answers
Hi, from what i can understand so far about the fridge/freezer with all this problem, i think the fault is from the control board since the compressor, fan and even the fridge and freezer are not working and to cap it all, the light works on and off.
You have to replace the control board.
Take care
  • 1 more comment
  • Shehu Pro
    Shehu Pro Apr 25, 2010
    Hi, it's behind the fridge/freezer, around where the compressor and fan is located..
  • Shehu Pro
    Hi, am so sorry about the mistaken identity of the problem, i meant to say Circuit Board and not the control panel. The control panel is usually located where you have the temperature display..
    Thanks for the correction.
  • Shehu Pro
    Hi, maybe you should try changing it since there is no power in it..
Why is my refrigerator not cooling properly?
Low on refrigerant gas due to a leak
Broken thermostat
Failing Compressor
Iced up evaporator
Feb 03, 2016 | Frigidaire Refrigerators
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer is too cold, refrigerator does not work
The problem is with your defrost system. If you remove the back panel of the freezer you will probably find a solid block of frost/ice. This restricts your airflow across the evap coils not allowing air to circulate to the ref side. It could be a problem with your defrost heater, termination, or defrost control. Your termination will be located at the top of the evaporator coils when you remove the back panel you can usually do a visual inspection of the component to see if it looks "popped out or swollen with ice" the heater can be tested for continuity. If the heater ohms out ok then the easiest thing to do would be replace the defrost control and termination. You will need to let the evap coils completely thaw out with a heat gun or by turning the unit off w/ the doors open for 24 hrs before plugging it back in after replacing components.
Also make sure your evaporator fan motor is running in the freezer to pull the cold air over to the fresh food side. If its not running then you probably have a bad evaporator fan motor.
Let me know if this helps _MJ_
Feb 07, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer is not cooling
take the back out of the freezer and look at the coil it should be completly frost on it if not it could be a sealed system prob
Dec 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 106.536323000 S/S: Not Cooling Enough
YOU HAVE A DEFROST PROBLEM. FROST HAS BUILT UP SOMEWHERE AND THE FAN CAN'T BLOW PAST THE BLOCKAGE. OR ONLY A SMALL SECTION OF YOUR COILS IN THE FREEZER ARE COOLING DUE TO A CLOGGED FILTER OR BAD COMPRESSOR. PULL THE BACK COVER FROM INSIDE THE FREEZER AND LOOK AT THE COILS. THEY SHOULD HAVE A LIGHT FROST AVER THE ENTIRE COIL.IF IT IS A BIG BLOCK OF ICE YOU HAVE A DEFROST PROBLEM.
Oct 28, 2009 | Kenmore 53642 / 53644 Side by Side...
M refrigerator isn't cooling the evaporator coil was full of dust it looked like it had a sweater over it but it still isn't cooling after I cleaned it what should I do
Don't you mean your CONDENSER (the black tubes found at the back of your unit or below it ? Those are the ones that dissipate the heat - if they are at the bottom, there is usually a fan blowing air on it, if applicable, check to see if it is spinning, when the compressor is on.
The EVAP coils are the ones you find when you remove the freezer's back panel, you will see a fan there, blowing the cool air from the evap coils.
If the evap coils in your freezer are over frost it will cause cooling problems, in which case your defrost system is not functioning and you will need to change the control board and have the defrost components checked to make sure everthing else is working.
Sep 25, 2009 | Kenmore 53092 / 53094 Side by Side...
Left not transfering cold enough air to right side. doesn't get colder than 50 degrees, why?
Remove back panel of freezer (where you see the frost) and melt the frost with a hair blower. The frost blocked evaporator coils are not allowing air to pass over the cold coils, so no cold air is able to get to the fresh foods section. You will most likely need to replace the defrost heater at the bottom of the evap coils to prevent this from reoccurring in two weeks time.
Nov 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore freezer and fridge is not cold - not frost build up - compress anf fans are all running
You need a qualified technician for this problem.
- Your unit may have leaking try to check for oil traces.
- The system maybe restricted, system reprocess is needed for this unit.
- If the unit is no frost try to check if there is an air circulation inside the unit. If no air is present then check your fan motor inside.
Jan 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
89 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
