Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
How to install engagement deck cable for mtd lawn tractor
  • 376 Answers
SOURCE: how to remove rear wheel of lawn tractor
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
Posted on May 15, 2009
GM Elec
  • 1000 Answers
SOURCE: Need parts manual for Craftsman 22HP 50 inch deck lawn tractor
Go to "sears.com", have your model number ready and go to the parts link. You will beable to view an exploded view of your mower and order parts on line if you like.
Hope this fixes your question, let me know.
Regards,
Posted on Jun 12, 2009
wadembly
  • 489 Answers
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Posted on Jun 14, 2009
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
I need to replace the deck engagement cable.
Craftsman Mower Deck Engagement Cable install - YouTube
? 6:26
www.youtube.com/watch?v=q6cKjePhdqw
Jun 27, 2013 - Uploaded by redneckcomputergeak How-to install a cable engagement on a craftsman lawn tractor. Craftsman, Poulan, AYP, Husqvarna part 175067, 169676 Deckclutch cable with ... seat, but other than that the video was a HUGE help in replacing that cable.
Sep 25, 2015 | Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
MTD GOLD LAWN TRACTOR WHEN ENGAGE PTO AND LOWER DECK . SLOWS DOWN TURNING BELT SLIPING
Belt is worn out and needs replacing or maybe the jockey tensioner is not operating on the belt hard enough to prevent slippage. If its all in good condition get a good DIYer or mechanic to have a look. If not its down to your local garden machinery shop.
Apr 27, 2015 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
Deck engagement cable installation
If this is for the models with the handle along side the seat ..the cable attaches to the end of the of the the handle and then runs behind the seat under the rear fenders and then snakes back to the deck where it to a spring on the deck or a spring that comes with the kit...the cable plus on the spring to get the tension on the belts...some differ but presets much the same.system ..if the ok'd or broken one is still on use it as an example..good luck
Sep 01, 2014 | Arnold OEM-190-116 38-Inch/42-Inch Mulch...
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I changed all 3 belts on my MTD lawn tractor, now the engine turns over but will not start
check to see if you have spark to the plugs when you are cranking it over. If not then one of the safety devices is keeping it from starting. there is one under hte seat, one on the deck engagement lever and one on the clutch pedal
Aug 09, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
Deck belt does not engage blades on riding tractor
Be sure the belt is the correct size and is routed correctly.
If you are not sure, you can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Apr 18, 2009 | Oregon Scientific Electric PTO Clutch for...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
692 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
