Question about Bose (321GS) System
Bose 321 gs II
Remote fails to operate the system, batteries have been replaced
  • 4,102 Answers
Hi does the remote have an led light on it or not if it does is it flashing when you press button.
If not then check the battery terminals are clean if it still dont work then try removing the case as their might be a button jammed as this would cause the problem your having also with the case off clean behind the buttons incase of grease or damp clean the contacts and then put back together usuall this does the trick.
It could be jammed button or grease behind buttons this is the usuall problem with most remotes unless they have been dropped on hard surface damaging the internal components
Posted on Mar 23, 2008
  • Bose Master
  • 19,396 Answers
Probably you need a replacement remote
  • Ginko
    Ginko Mar 23, 2008
    Check first that there is no obstacle between your system and the remote, as this can prevent remote from working. Check also that system is working without remote, eventually unplug the system from power outlet and plug it back. Ensure that batteries you are using in your remote, even if new, can work on a different devige, eg. a torch.
    If all the above does not work you will need to buy a replacement remote for your bose system or use a compatible universal remote.
    regards
  • Ginko
    Ginko Mar 23, 2008
Bose 321 device code for Kogan UHD TV
Your Bose remote may not work with your Kogan TV.
Aug 12, 2016 | Bose 321 GS series II
Power cord is broken on my bose 321
Is the power cord bad, or the jack in the unit that you plug the AC cord into broken? If you're interested in repairing your Bose, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 22, 2014 | Bose 321 GS series II
I need code to program 321 remote. I have a led insignia t.v.
Click on the link below and you will fond the manual for your unit. Go to page A-2 for the beginning of the remote codes for all devices. Select your device and program. You are all set:
http://worldwide.bose.com/productsupport/en_us/assets/pdf/guides/321/en/og_en_321_series2_321gs_series2.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 04, 2011 | Bose 3·2·1 GS II System
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Done!
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
How do i program bose 321 remote to work with comcast box
look at your cable box and see what company actually manufactures the box. Mine was Motorola.
Mar 11, 2010 | Bose 3·2·1 GS II System
My child messed with the settings on my 321 bose
Reset all EQ settings to 0 for a starter. It sounds as if it is EQ'd down all the way.
Jul 05, 2009 | Bose 321GS Series II System
Bose 321
3 audio inputs (3 analog, 3 coaxial digital, 1 optical digital)
2 video pass-through inputs (composite and S-video)
Video output for TV (composite, S-video, and component)
Media center • 3 1/4"H x 13 3/4"W x 10"D • (8.3 x 34.9 x 25.4 cm) • 6.7 lbs. (3 kg)
Remote control • 1 1/8"H x 2 1/2"W x 9"D • (3 x 6.5 x 22.9 cm)
Gemstone speakers • 2 1/2"H x 5 1/2"W x 4 1/8"D • (6.4 x 14 x 10.5 cm) • 1 lb. (.45 kg) each
Acoustimass module • 14 1/2"H x 8 3/4"W x 19 1/8"D • (36.7 x 22.2 x 48.5 cm) • 23.3 lbs. (10.6 kg)
Total shipping weight • 44 lbs. (20 kg)
gray_hr.gif What's In the Box • Acoustimass® module • Media center • 2 speakers • 3·2·1 universal remote control • Setup DVD • Antenna stand • Stereo cable • Video cable • Speaker cable • Module cable • Rubber feet for Acoustimass® module • Rubber feet for speakers • Batteries • AM antenna • FM antenna • 120V power cord • Quick setup guidepls rate !!!!!!
May 29, 2008 | Bose 321GS Series II System
Bose 321 gs II
Try unplugging all of your audi and video cables and see if you have the same problem I do.
Mar 23, 2008 | Bose (321GS) System
Bose 321 won't play CD and VCD but plays DVD
I did have the same problem. Then unplugged / replugged the base cable (= also the power supply) and after this the Bose dis play CD's again.
Feb 29, 2008 | Bose 3·2·1 II System
Bose (321GS) System Logo
49 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
