Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Bell tone what is the bell tone that chimes
  • BRIAN
    BRIAN May 11, 2010
    MAYBE THE DOOR OPEN ALARM
    Scholar:
  • 126 Answers
DOOR ALARM IF LEFT OPEN LONGER THAN A MINUTE. OR REGULAR DOOR ALARM EVERY TIME IT IS OPENED. THE MANUAL MAY TELL YOU MORE.
Posted on Apr 25, 2010
WIRELESS DOOR BELL BUTTON SL-1695-rx
Heath/Zenith SL-6166-C Wireless Plug-In Door Chime Kit ...
www.amazon.com > ... > Door Chimes & Bells > Kits
Amazon.com, Inc.Heath Zenith SL-6198-B Wireless Doorbell Replacement Battery. Total price: ... Plug-in doorbell chime, doorbell button/transmitter with battery, hardware pack ...
Oct 16, 2015 | Home Security
Can I add a second chime for upstairs working from the existing bell push
Most likely, but unless it is wireless, you will need to run bell wire from the downstairs chime to the upstairs chime unless the wire appears to be available any way. Probably just the connections are needed.
Mar 28, 2015 | Home Security
How do I set the chimes
Chimes are usually set from inside the bell-push, so that you can have multiple bell pushes and different chimes for each one.
Feb 13, 2015 | Home Security
7 dings and a beep when starting 2000 ford explorer? what does that mean
NOTE: The generic electronic module/central timer module (GEM/CTM) is connected to the ISO link and is diagnosed through the data link connector (DLC) with a scan tool.
There are five warning chimes and lamps the GEM/CTM controls: headlamps operating without the ignition on (chime only), door ajar (chime and lamp), key-in-ignition (chime only), driver seat belt warning (chime and lamp), and message center.
Audible Warnings Warning Condition Lamp Duration Audible Duration Audible Output Safety Belt 60 Seconds 6 Seconds Chime, 60/Min. 740 Hz Key In Ignition - Continuous Chime, 120/Min. 740 Hz Headlamps On - Continuous Chime, 240/Min. 740 Hz Door Ajar Continuous 1 Second Single Tone, 1000 Hz Message Center (Tone Request) - 1 Second Single Tone, 1000 Hz
When the is turned to RUN or START from OFF or ACC, the chime will sound for six seconds or until the safety belt is buckled.
The will turn on for 60 seconds or until the driver safety belt is fastened. Both the chime and the lamp turn on at the same time.
If the safety belt is buckled before the ignition switch is turned to RUN or START, from OFF or ACC, neither the chime nor lamp will be activated.
Anytime the is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed or the safety belt is buckled.
When at least one door is ajar and the key is in the RUN position, the door ajar cluster lamp is activated and remains on until all doors are closed. A warning tone will sound once any time the key is in the ignition switch and any door is open.
The key-in-ignition warning will sound when the driver side is opened with the key in the and the in OFF or ACC. It will continue to sound until the key is removed, the is closed, or the is in RUN or START.
The headlamp-on reminder chime will be activated if the headlamps or parking lamps are on, the key is not in the ignition switch, and the driver door is opened.
A single tone will be provided each time a ground signal is received from the message center. A one-second tone will sound for warning indications from the message center. A 100 milli-second tone will sound for each message center button depressed.
Feb 12, 2015 | 2000 Ford Explorer Eddie Bauer
Setting the codes for the door chime
Presuming that you are asking how to set codes for the Desa International door chime, here's a solution:
There are two components of the Desa door chime --- the ringer assembly and the door button. Inside each component is a set of eight pairs of pins and several square-ish plastic jumpers. To set a code, you must push jumpers onto the pair of pins for each of three different numbers. (You may find that you have more than three jumpers. If so, the others are spares which you can tell because they will only be covering one of the two pins in a pair.) Whatever three numbers you choose, the ringer and button must match exactly. 5-6-7 seems to be the default set-up as delivered from the factory. This is only a problem if anyone else in the neighborhood also has a Desa chime with this setting. If you use pin 8, the ring changes from a two-tone chime to a 16-note sequence.
Aug 26, 2014 | Desa International White Wireless Plug In...
I have a IQ America doorbell with 5 chimes and 5 tunes and the bell only plays a sorta gong which cannot even be heard How do I fix this problem so that it plays a chime/tune?
We had a similar problem with a wired doorbell. There is a diode in the doorbell itself that causes the chime to ring fully. If the diode is backwards, you get just a small tone and can only hear the full chime if you hold the button down. If this sounds like your problem, open up the doorbell at the button end (or have an electrician do it) and reverse the diode.
Nov 07, 2011 | Desa International White Wireless Plug In...
Tone chime E5 is out of tune and sounds flat. Have replaced the head and this did not solve the problem. What else do I need to do?
"sounds flat" ... What are you comparing this to? Pianos at that range are sharped due to stretch tuning so this would appear flat compared to the piano. Use a Korg or other brand tuner to verify. If it is flat, my educated guess is there is a crack in it. Dip it in a vegetable dye water mixture and usually cracks will show up. This is almost like Magnafluxing they use in the aircraft industry. These are likely made of aluminum and repair if cracked would be hard... one could try to have it welded and then filed down to tune it. I have done this with sleigh bells on a pipe organ, but those were brass.
Apr 20, 2011 | Suzuki 25Note Chromatic Tone Chime Set
Wireless door bell rings when no one there
most likely on the same frequency! They have a pretty good range on them, I'd go but a different brand!
Jan 07, 2010 | Kitchen Appliances - Others
Chime on steady tone with the headlights on
try removing your battery terminals then put it back again to reset the system of your car back to original
Jul 02, 2009 | 2001 Volkswagen Jetta TDI
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
281 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
