Question about GE Profile JVB67 36" Telescopic Downdraft Ventilation System: Bisque on Bisque Kitchen Hood
I am having a similar problem...motor hums like it is trying to lift vent but doesn't. I removed entire vent today...should I start by replacing motor? When I plugged in unit after removal I can hear and see motor trying to move but it will not turn gear to actuate the lifing of the vent. Any suggestions? Tom
    Scholar:
  • 126 Answers
YEP REPLACE THAT MOTOR. MOST OF THEM HAVE A GEAR TOOTH THAT HAS BROKEN WHICH CAUSES BINDING.
Posted on Apr 25, 2010
Dryer heats but doesn't completely dry clothes.
See if you could turn the machine and remove the vent hose on the back.
Then, after you are sure it is clear, try a load of clothes with the vent hose blowing out into the air, not hooked to a vent hose pipe through the wall.
Very often, a plugged pipe will cause this behaviour. The pipe could be plugged in the wall or somewhere else.
Be blessed.
Feb 18, 2013 | Dryers
Motor hums doesn't start
What is the model number of your unit?
Oct 31, 2012 | Kenmore Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
My front load dryer will not start. We just changed the fuse and it was squeaking. Now it won't start. The belt is not popped we checked. it just hums and it doesn't turn
hums and doesnt turn would be along the lines of bad motor try using your hand on the inside of the drum to push the drum around if it is hard to push you will most likely be looking at having to replace the motor if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
May 10, 2011 | Dryers
Driying fan does not stopps
I think what you are describing is the "turbo fan" assembly. This device is used to remove the condensation to insure dishes are dry at the end of a cycle. It actually vent`s out the bottom left side via a plastic housing but the vent motor assembly is located inside the door at the upper left corner under the circular cover
i.e.
If it ( the fan) continues to run or "hums" because it`s trying to run, even when the dishwasher is idle or no program has been selected, it is likely a problem within` the control board unfortunately.
This is usually caused by the vent assembly getting clogged up so it cannot open correctly and the "wax motor" ( the small device which open`s and closes the vent ) burns up and short`s out the control board.
You can see the small wax motor in this image, the brown/red brick shaped device on top of the fan housing...
i.e.
If you`re capable, you can visually inspect the control and look for burnt up path ways on the printed circuit side ( green side with lot`s of solder joints ). It may be pretty obvious as soon as you see the control as it was ith this one I attached here,
i.e.
If so you`ll need to replace the control as well as the fan assembly, or clean the assembly really well,
i.e.
6
Clean all the fan blade a vent thoroughly and reassemble with the new wax motor and control and you should be good to go.
You may opt to just replace the entire fan assembly, it is available and comes as complete,
i.e.
Most asko control`s come with a new "wax motor"...or used to where I live. Unfortunately those control`s retail for about $400 and up, and most now are of the "rebuilt/refurbished" kind. The part number should be ( if the model number is correct ) # 8801201.
Hope this help`s move you forward. Let me know either way and I`ll try to assist you further.
Thank`s for visiting FixYa today for your repair solution`s and good luck moving forward. Please take a moment to rate the info I provided for you today and again good luck.
Regards,
Macmarkus :)
Dec 21, 2010 | Asko D1776 Stainless Steel Built-in...
Hums but wont fire
Remove the top cover, plu it back in and see if the hum goes away, if it
doesn`t look to see if the fan is stuck, if it is unplug and try to spin it
by hand, if it wont spin replace the fan motor
Feb 12, 2010 | Reddy Heating & Cooling
Ford Taurus 1999SE-Windshield wiper motor just hums.How to fix ?
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Disconnect the battery ground cable.
  3. Remove the wiper arms.
  4. Remove the 8 plastic retainers and the 6 clips holding the cowl vent screens to the inner panels. Turn the retainers 1⁄4 turn counterclockwise to remove.
  5. Remove the cowl vent screens.
  6. Disconnect the electrical connector from the wiper motor and remove the 4 bolts that mount the module assembly to the cowl.
  7. Remove the windshield wiper module from the vehicle.
  8. Rotate the wiper operating arm in a clockwise direction to gain access to the bolt retaining the arm to the motor. WARNING
    Always rotate the wiper operating arm in a clockwise motion or damage to the motor could occur.
  9. Remove the nut retaining the wiper operating arm to the wiper motor.
  10. Remove the three wiper motor-to-wiper module assembly retaining bolts and remove the motor from the vehicle.
To Install:
  1. Position the wiper motor on to the module assembly. Install the three wiper motor-to-wiper module assembly retaining bolts. Tighten the bolts to 115-151 in lbs (13-17 Nm).
  2. Position the wiper operating arm on the wiper motor output shaft. Install the mounting nut and tighten to 22-29 ft-lbs (30-40 Nm).
  3. Position the windshield wiper module onto the cowl. Install the mounting bolts and tighten to 106 in-lbs (12 Nm).
  4. Connect the wiper motor electrical connector.
  5. Position the cowl vent screens onto the inner panels. Install the 8 plastic retainers and the 6 clips holding the cowl vent screens to the inner panels. Turn the retainers 1⁄4 turn counterclockwise to install.
  6. Install the wiper arms.
  7. Connect the battery ground cable.
  8. Adjust wiper arms if necessary.
Here is the picture of the motor....it is the round object in the middle of the picture that looks like a can and has a square block on the end of it.
You have to remove the cowl vent panel....just under the windshield. $64.00 for a new motor.
Oct 01, 2009 | Ford Taurus Cars & Trucks
Rear Windshield Wiper Motor
look closely/carefully for recessed screws. Most are usually pop on/ pop off types. Pull/ pry gently.
Jul 17, 2009 | 1998 GMC Jimmy
Kitchen Ranges Logo
785 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
