Question about Toshiba Satellite P105-S6104 Notebook
TOSHIBA HDD Hi to all. I have a Toshiba Qosmio G20 Notebook. The notebook has 2 HDD. The first HDD has a hidden partition for the Qosmio Player. This partition is hidden by HDD firmware modification. Bios see's the first HDD with 79GB and the second with 80GB. According to Toshiba in my version of the notebook the last 100MB of the first drive are hidden by a modified version of the firmware. So I want this 100MB back. For the past 2 years I've been looking for ways que recover these 100MB. Can anyone help me find a way to reflash my Fujitsu 80GB HDD Sata model MHT2080BH. Since both drives are exactly the same some third party software to copy the firmware from the second HDD to floppy and then flash it to the second HDD.
  • Anonymous Nov 24, 2008
    hi dear ,
    i have a same problem, like when i install win xp on qosmio g-20 , win files are copying fine , but when i restart my laptop its showing only black screen, but only cursle blinking, if any know about the solution of it, plz let me know about it,
    mail on "luckyq_786@yahoo.com"
    thanks in advance
  • Darrell Kittle Jr
    Darrell Kittle Jr May 11, 2010
    Do you still have all your Original OEM recovery discs?
    PAeasop
    Genius:
  • 1,027 Answers
I would suggest running linux based GParted live cd. Under linux you can alter the sizes of partitions and configure the partitions and format in NTFS/Fat32/
If you want to try
click on the Download the latest version
From Tuxfamily : http,
gparted-livecd-0.3.4-11.iso
Posted on Mar 24, 2008
Qosmio f60 fan goes on high speed and freez. It keep freezing.The only way to reboot it is to hold down the power button to turn it off and then turn it back on.
I have the same "computer" qosmio f60. I've replaced the hard drive, installed a new window 7 OS, changed RAM paging, power options, run the things with a fan pointed at the computer fan.
The fan goes to high speed and the HDD LED unblinking. I've brought the laptop to two computer shops whose owners knew less about computers than I did. I tried to go to a Toshiba recommended shop in Toronto except they changed to Apple-service only. I tried phoning Toshiba, they just want to change 4 bucks a minute for technical assistance. I've had this Toshiba-thing going on 3 years with the troubles starting after the first year. No one cares about this problem. If I see a Toshiba factory I'm going to chuck this red brick of cra through the window.
BTW it's not a virus or rootkit. I had to learn how to partition a HDD sector through some crazy BIOS program before installing windows. There's no virus or rootkit that's causing this problem.
It's mostly been freezing on me with games.
Aug 31, 2013 | Toshiba Qosmio G15 Notebook
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
What is the Toshiba Laptop L305D-S5881 Hidden partition?
If your laptop has a recovery partition (hidden partition) then you can -
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jun 29, 2012 | Toshiba Satellite L305D-S5881 Notebook
How do i reset the m305-s4910 to factory setting
Recovery
  • How to recover a Toshiba notebook with the HDD recovery procedure
  • http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
From CD
  • http://cdgenp01.csd.toshiba.com/content/support/downloads/PMA500339010_web.pdf
You may have a hidden partition on the harddrive - if so you can recovery from there - BUT - you should also be able to create some bootable recovery DVD or CDs from the hidden partition using the toshiba recover cd creator Two ways to get to the hidden partition on Toshiba
  • Press an hold the zero key and power on - this will enable the recovery menu
OR on later models
  • Tap F8 as it boots and then use repair computer - from menu
  • How to recover a Toshiba notebook with the HDD recovery procedure http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
if not you can order replacement recovery cds
  • https://backupmedia.toshiba.eu/landing.aspx
Apr 10, 2010 | Toshiba Satellite M305-S4826 Laptop
Hi I have a Toshiba Satellite L40-18Z I want to perform a factory reset as it is running slow because it is full of usless junk and I do not wish to keep any files or programs but I do not have a disk. Is...
two ways to get to the hidden partition on Toshiba Press an hold the zero key and power on - this will enable the recovery menu OR on later models Tap F8 as it boots and then use repair computer - from menu
if not you can order cds https://backupmedia.toshiba.eu/landing.aspx
Mar 24, 2010 | Computers & Internet
Hard drive not seen in windows xp
It is not showing up in XP yet because it has to be partitioned and formatted first. You can see it in disk management and partition it from there, then format it.
Apr 15, 2009 | Toshiba Qosmio G25-AV513 Notebook
BSOD - NV4_disp.dll - Toshiba Qosmio G10-133
Re-install Windows, at the start ofthe installation, delete the partition, the create a new partition, the do a full NTFS format.
Mar 17, 2009 | Toshiba Qosmio G10-133 Notebook
Open up a toshiba qosmio f25 av205
http://www.irisvista.com/
This site has free info and Pic to open up the laptop.
one screw is hidden under monitor cable.
look up replace video card.
Ckreuzer
Dec 26, 2008 | Toshiba Qosmio F25-AV205 Notebook
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Need motherboard for qosmio laptop. do I have to replace w/same
they make an ata to sata conversion cable that you can buy, look on the boxes of the hdd's most of them come with the converter that you need
Dec 03, 2008 | Toshiba Qosmio G15-AV501 Notebook
Toshiba Satellite P105-S6104 Notebook Logo
574 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
