I need an instruction manuel for a whisper cool portable air/swamp cooler.
  • corbeze May 11, 2010
    please provide as much as you can.. model# serial# whispercool is known as a brand and also a model, so i also need more clarification, then i can provide. thanks.
  • spinella812
    spinella812 Jun 24, 2013
    Whisper Cool P200
boysor2933
  • 293 Answers
SOURCE: Frequent short cycles of the Mastercool swamp cooler
Try to replace the thermostat. Short cycling of motor only happens when the thermostat is set to a very high temperature.
Posted on May 27, 2009
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
  • 340 Answers
SOURCE: swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Posted on Jun 26, 2009
  • 340 Answers
SOURCE: Breezair swamp cooler parts
applianceparts.com try the manufacture web site johnstonsupply.com should have a pump you can make work. Tom
Posted on Jun 28, 2009
  • 396 Answers
SOURCE: Do not know how to work/maintain swamp cooler
Evaporative coolers are only for dry climate conditions or deserts. They cannot cool as much as central air or air conditioners which have compressors and refrigerant. The mechanics are simple requiring a water float valve, pump, spider (water distribution), aspen wood pads, blower, belt, motor, and switch. The unit must have a water supply to replenish the system due to evaporation. Your system may have a float valve which you need to adjust to shut off when the water pan is full. Floats can be adjusted by loosening the pivot screw and moving the float up and down to adjust the turn off level or by turning the float to extend or retract the length changing the water shutoff position. You do not want the water to be so high it flows out the over flow tube but the water should cover pump base. Plug in the unit and turn the switch to pump if you have that option on your unit. This will engage the pump to force water from the pan up to the spider to saturate the pads with water. After a few minutes turn the switch from pump to low or high cool. New aspen pads will have an distinct smell which will go away after a few days of usage. If you do not have a pump setting turn the switch to low or high cool which will blow warm air at first then start to cool down. You may also have a fan setting which will blow outside air without any additional cooling if the outside air is humid. Occasional maintenance is to make sure the pump is pumping water and the filter basket is clean and all the spiders are working with water flowing freely. You can use a flexible wire to force it in a spider tube to clean it if it is clogged. You may want to change the water after a month to keep the system cleaner from slime and calcium. At the end of the season disconnect the water supply and drain the water pan blowing out the water line if the winter is below freezing. Replace the pads if they have calcium build up or dry. Flush the water pan out and clean the Add some oil to the pillow blocks which are the bearings at each end for the blower. Check the belt and pulley for excessive wear. Cover the unit with canvas to prevent cold air from coming in during the winter. Next summer season all you have to do is uncover the unit and hook up the water supply.
Posted on Jul 27, 2010
How to remove a motor from a plastic fan wheel on a portable evaporative cooler
There should e a set screw on it that you can loosen. Then the wheel can be removed.
May 31, 2014 | AdobeAir Mobile Swamp Evaporative Air...
Can you usen the sam air vent for heating and swamp cooler
Yes you can. I have that set-up in my house. The only problem is when moisture laden swamp cooled air goes past the heat exchanger. This could cause the exchanger to rust out, allowing carbon monoxide to come into the house when the heater is used. This can be avoidid by having a one way damper made by an HVAC shop, and installing it at the heater.
Apr 16, 2012 | Mastercool 67680 Evaporative Cooler Air...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
NEED TO KNOW HOW BIG AN AREA A 10,000BTU SWAMP COOLER WILL COOL.
That will cool a normal size room. The cooling capacity depends on a lot of things like how well insulated the room is.
Jul 20, 2010 | Mastercool Portable Air Conditioner
How could i clean the air cooler, i used have a bad smell when i switch on the cooler fan
What you do is remove the hog hair and replace it. Then clean out the pond. Then remove the blower and take it apart, oil the motor and wash the wheel.
May 04, 2010 | Cfm Kenstar Turbocool Major Portable Swamp...
How to turn it on? wisper cool
Try this : http://www.impco.com.mx/manuales/artic/Manual%20MMB8.pdf
Jul 08, 2009 | AdobeAir WisperCool MMB8 Portable Air...
Heating & Cooling Logo
509 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
