Question about Philips Televison & Video
When we press any button, all we get is the the red light on top left side of remote light up. channnels will not change, volume not change, won't power on or off. how can we fix this.
    Sniper:
  • 52 Answers
Sorry but without knowing the particular model number of the remote control or indeed whether or not it is a philips universal remote control, I can't give you a definative answer to your problem. I recomend however, if you haven't changed the batteries in your remote that you put new one's in as the batteries maybe too weak to operate the remote fully, this will at least eliminate this possibility. If you are using using a Philips universal remote control then try resetting the remote using the correct code for machine, if you don't know the code then try the Philips support website for the code for your tv. After that I would consider that either the remote or the machine has developed a fault where the remote's I/R no longer transmits or the machine's I/R receiver no longer works. Personally I would purchase a cheap / middle of the range universal remote and try that to see if that works as it is a much cheaper option than having the machine looked at by a technician. If you would rather there are online sites where you can by genuine remotes for most tv's etc but obviously this is a more expensive option than a universal replacement.
Hope this helps,
James
Posted on Apr 25, 2010
Chunghop universal remote RM-306E code for lg tv
if you are using CHUNGHOP RM-306E this would be applicable for all brands of TV..
1) Turn on the TV
2) Press S button (top left corner) until red light on
3) Press Green button (power button top - right corner)
4) press volume + button (blue at the middle on the left) until the volume signal display on the TV
5) press S button again
Now you are set..
Test the remote function it should be working now.. if not repeat the steps above until you got it working..
Good luck..
May 07, 2014 | Televison & Video
Universal remote
Hold top left but until red light blinks. Enter code and press the volume button continuously
Apr 26, 2013 | Televison & Video
How to program remote to dish? 4.4 IR/UHF PRO
Your question is not clear as to whether you want to program the remote to your TV or the DISH receiver. Here are steps for both if this has not been resolved already!
DISH RECEIVER::
1. Go to the room where the receiver is located. With the remote for THAT room press menu twice. (This will be the remote with the Green 1 on the bottom.)
2. Press and release the SAT button on the top left of the remote
3. Press and release the black and red record button 3 times
4. Look that the number next to remote address (secondary Remote address) has changed.
5. If not, start again.
TV::
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Aug 13, 2011 | Universal Remote Control DISH Network...
Sky remote code ????
Hello
Check these codes.
065 244 405 318 037 398 191 459 245 389 060 275
742
743
726
508
584
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*
Point the Sky+ remote control at the TV and try the volume button.
OK.
Jul 04, 2011 | LG 47LC7DF 47 in. LCD HDTV
Need code for urc-3605 for bell express vu satillite
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 16, 2010 | One For All URC-3605 Remote Control
3.1 DishnetWork remote problem
I suspect that the remote address got changed somehow. Pree and hold the sat button on the top left hand side of the remote until all buttons light up across the top and release. Now key in 0-1 on the numeric keypad and press the pound sign. The SAT button will flash three times. After it the SAT button is done flashing press the small red dot record button. Now try to operate the remote. You should be able to control the system now. Thanks for using Fix Ya.
Mar 13, 2009 | DISH Network IR Remote Control
SAT button it does not work, you can not turn on or off the DISH
First press the SAT button at the top left hand side of the remote and release. Now try changing channels. If this did not work press the menu button twice on the receiver. It will usually be behind a pop open door on the right of the receiver. I f your receiver does not have these buttons you can access the system info screen by pressing the power button on the receiver while holding down the arrow left or right key.
Once you have come to the SYSTEM INFO SCREEN press and hold the SAT button on the top left side of the remote until all lights across the top light up. Then key in a two digit number e.g. 01-16 and press the #key. then press the record button and the remote address for the location you are trying to control should change to the number you keyed in. If this is the second location tv that was giving you issues exit out of all the screens on the receiver location tv and go to the other location and try the remote. If it is the tv where the receiver is located then you should now be able to use the remote to maneuver the yellow cursor across the screen. If you need further assistance please let me know. Thanks for using Fix Ya.
Dec 11, 2008 | DISH Network IR Remote Control
Echostar IR remote (Dish)
to set remote to tv
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
Code for satellite bell (expressview)
Jan 03, 2008 | Televison & Video
Remote control problem
try pressing the TUNER button on the top of remote before pressing these buttons
Nov 27, 2007 | Yamaha RX-V420 Receiver
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
