Question about Belkin (F1UP0001) Print Server
I cant get the wep key and i try to put the ip adress in and it wont come up
  • 2,260 Answers
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that
computer.
router set up page is the page where you can check all the
router settings.
Click Here for more information about the routers and
network
Posted on Apr 25, 2010
Ip adress timed ou
Try power-cycling the router (unplug and plug back in). Make sure wifi is enabled on psp (green light @ bottom left, toggle switch is on bottom left of psp). Also, when typing in encryption key, make sure the encryption protocol settings on the psp are the same as what your psp is broadcasting. So if your router is broadcasting WPA/WPA2 encryption, make sure psp is set to that.
Hope this helps.
Oct 25, 2011 | Sony PSP 3000 (0 MB) Black Console
I have a motorola router and the ip adress is 192.168.15.2 and i don't know where to find my WEP key.please help...
what is the model number?
Normally you can log into routers by entering the ip into internet explorer, the WEP/WPA wireless keys should be under the wireless settings tab.
Oct 17, 2010 | Computers & Internet
Im trying to get online for my xbox 360 ive just bought a wireless adapter but it says i need a wep key wat should i do
you have to get the WEP key off the router on your home network. sometimes the key will be on the wireless router but not usually. you would have to log into the router using your ip adress 192.168.1.1 is usually the default. you need to log into the router and go to security settings to see the WEP key
Jul 06, 2010 | Microsoft Xbox 360 Console
Computer won't connect even though the link is 100%?
it have problem with your
Expoler or IP is not contacting with your Router
please try from
Start , run , type your IP Adress
Ex.p //:192.168.1.1
if your getting your ping then chack your router are u coneted with your DSL provider
if not then just mail me on (m42153@gmail.com) i will try to help you out
Apr 15, 2010 | Trendware TEW-424UB (0710931502572)...
Cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
May 07, 2009 | Nintendo Pokemon Pearl Version for DS
Cant connect to internet
put this # at DNS entry 4.2.2.2 and 4.2.2.1
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Wep address
Your wep adress? You mean your IP adress? Go to http://whatismyip.com/ and that number is your IP adress. Enter that manually, and your XBox should be connected.
Jul 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Cant Aquire IP Address Wirelessly
try this... connect the laptop directly to the router using a cable. get into the router interface and disable the wep security. Once it is disabled try connecting the laptop. your computer will ask you that network is not secured and ask if you want to connect anyway. just connect your laptop without the WEP key, if it connects, just go ahead and enable the security again. hope this helps.
Feb 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Ps3
If it's unable to find your router, then try moving it closer. 9x out of 10 this is the cause.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
Belkin (F1UP0001) Print Server Logo
194 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
