Question about GE Security Simon 3 Wireless Home Security System
System battery failure with AC power on - GE Security Simon 3 Wireless Home Security System
    Sniper:
  • 54 Answers
Your system uses the battery as a backup in the event of an AC power failure. This battery is constantly being trickle charged by the system. However, just like a car battery, each year as the battery gets older it also loses some of its capacity to maintain the system during a power outage. Normally after 4-5 years the battery needs to be replaced. In addition to your system keeping the battery charged it also monitors the battery's charging capacity. When the system fails to maintain a suitable charge the system will indicate a "low battery". It is probably time to replace your battery. You can normally find a replacement by going to a battery warehouse retailer in your town. Hope this helps you.
Posted on Apr 26, 2010
Testimonial: "Thanks. I'll try to replace the battery then."
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
Compaq A900 i replaced the dc jack the laptop wont charge bought new battery and charger and still wont turn on
A battery that will not charge may be as a result of an AC adapter failure, a system board failure, or a battery failure. You should therefore try to troubleshoot the power supply, the System Board and the battery. You can read more through the following site.
Sep 22, 2013 | Computers & Internet
1 long beep 2 short beeps
Hello Hardyjosef,
Below is the beep code chart for the mini 10 systems.
No POST
If the system does not perform a Power-On Self-Test, there are various things to look for:
1.Check that the system has a power light.
2.If the system has no power light, ensure it is plugged into AC power. Remove the battery.
3.If the system has power but is not performing a POST, Check for one of the following Beep code errors.
Beep Code Description Failure Coverage
1 BIOS ROM checksum in progress or failure. BIOS Chip Motherboard Failure or ROM Error
2 No RAM Detected No Memory Detected
3 Chipset Error (North and South Bridge Chipset, DMA/IMR/Timer Error for Intel platform); Chipset Error Motherboard Failure
Time-Of-Day Clock test failure.
Gate A20 Failure
Super I/O Chip Failure
Keyboard Controller Test Failure
4 RAM Read/Write Failure Memory Failure
5 RTC Power Fail. COMS Battery Failure
6 Video BIOS Test Failure Video Card Failure
7 CPU Cache test failure CPU Failure
8 LCD LCD Failure
4.With the power off and the system unplugged, remove all CRUs from the system and reconnect the AC adapter to the system and try again.
Try reseatting the memory to see if that will resolve the issue. If not, the motherboard may be bad and will need to be replaced. If you need another motherboard you can call the Dell Spare Parts Department at 1-877-717-3355 to purchase one.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jun 25, 2013 | Dell Inspiron Mini 10 Notebook
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
GE Security Simon 3 Wireless Home Security System Logo
852 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
