Question about Garden
Hi i need the settings for a carb on a gas trimmer Homelite model number sh2025ub24ra it also has a number em0865201 on it. homelite 02-98 is on it also. any help sould be great. it just wont stay rinning or idle
  • 333 Answers
Turn the set screws all way in.
Back them out 1 1/4 turn start it up let it warm up then adjust them in up to 1/8.
Depending on how it runs.
Posted on May 06, 2010
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Diagram for fuel lines on 25cc homelite ut20811b gas trimmer
Hi martinez7568
I believe the picture below is what you are looking for.
Please take time to rate me
Bud
Oct 22, 2012 | Homelite Garden
Need a manaul for my homelite gas trimmer
You should be able to find your manual here:
http://www.homelite.com/service_support/product_owners_manuals
Look for the serial number plate on your machine; it should aslo have a model number. Use the model number to find your manual.
Thank you for using FixYa!
Aug 20, 2011 | Homelite Mighty Lite Lawn Trimmer
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite 26vt Mighty Lite carb settings
Setting up the carb right on a trimmer is like setting one up on an RC gas operated car. It takes someone with a good year,and a lot of experience doing it. If youre new at it,youre not just going to be able to get it tuned,well you could,if you want to spend a few hours. Just take it to someone who does it,they wont charge you much and it will save you a lot of aggrevation.
Aug 13, 2009 | Homelite Mighty Lite Lawn Trimmer
Fuel line on Homelight
the filter in the gas tank that line goes to carb
and the one that line goes to bulb
Jul 18, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Trimmer wont stay runnning when I move the choke off full.
most likely its a homelite
Will it run at half choke?
Spark plug gapped .025-.030?
You did mix 2 cycle oil and gas? 40:1 not outboard motor oil
Check your fuel lines closely move them to make sure none are broken?
Check your primer bulb?
Make sure you look in side your fuel tank and make sure you can see your filter is still intact with the fuel line?
Ethanol fuel? 10%or less?
Stabilizer in your fuel?
low and high end adj. screws may need tweeking?
If they are capped you may or may not need a special tool to access
If they are not capped use a small screwdriver "note SMALL" turn and count the number of turns it takes to bottom out each adj screw marked H and L do not force once they both stop turning clockwise STOP!
Now bring them both back out the number of turns you counted with an additional approx. 1/4 turn.
Start trimmer as you would again and see what takes place. Better same or worse?
You may end up needing a carb. rebuild kit or diaphram kit?
Thats what i know for now maybe this may help or maybe not?
May 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
