Question about Stoves (161221) Heater
Blowing smoke inside not out!!!!!
Had a chirp like sound then the smoke blew inside and not out???? We are having a easter blow out!!!!
    Scholar:
    New Friend:
  • 70 Answers
Sound like the flue is plugged or dampener is closed.If that all checks out ok then i would clean the stove out and check for cracks in the inside of stove
Posted on Apr 26, 2008
My Maytag A/C is blowing out white smoke. What should I do? Is it blowing something in or is it something inside it? I had it on 75 degrees and on high cool.
If it's blowing very MUCH of it, then it's coming in from outside. There's very little inside an air conditioner that could possibly generate smoke, and VERY little that could possibly generate any LOT of white smoke.
Now... it's POSSIBLE, if your humidity is high right now, that it's blowing cold enough air to condense the humidity in the air, causing an actual cloud (just like the ones in the sky) inside your house. That can happen only when the humidity is very high, though.
Aug 01, 2014 | Maytag Heating & Cooling
Tractor blew white smoke started to sputter
Water getting inside of engine.
May 22, 2014 | Garden
1998 buick lesabre wont start. had a new thermostat installed last week as heater was blowing cold air. mechanic added anti freeze, car was running fine and blowing hot air. today the check engine light...
Sounds like you have water in the oil which means you could have a blown head gasket. Can you tell what got in the oil. Is it antifreeze or gas. If gas you probably have a injector sticking open.
Jun 23, 2017 | Buick LeSabre Cars & Trucks
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
S10 1999 pickup blew 4th spark plug 3 x's ,used a helicoil kit, now motor is smoking, whats the solution now?
It sounds like the area near the #4 spark plug is getting hotter than normal. Maybe an intake valve is not closing the whole way, thus letting the heat come out of the cylinder. I would get a cheap laser thermal dectector and measure the heat there compared to the other spark plug areas.
Dec 17, 2017 | Cars & Trucks
1989 1100cc virago sat for 9 months after being winterized so no liquids were in it. added oil, gas and new battery. got it to start and it blew massive blue smoke. then it quit. went for a ride around the...
When you say blue smoke, I assume you're meaning oil burning. Is there a characteristic oil burning smell to the smoke? Have you checked the compression? The blue smoke sounds like it could be caused by sticking rings. I personally never store a bike completely dry. I would change the oil before storage, fog the cylinders or run an ounce or two of oil through them with the plugs out, replace the plugs and, depending upon the anticipated duration of storage, either fill the tank with stabilizer and Marvel Mystery oil added to the fuel or drain the tank. A more likely scenario is that the smoke you're seeing is caused by carburetor floats not rising enough to keep the fuel in the bowl at the correct level. As far as the fuses blowing, you will need to isolate each circuit and trace it through. It's possible your wiring could have been chewed up by mice.
Jun 25, 2011 | Yamaha XV 535 Virago DX Motorcycles
`my 97 cavalier is blowing white smoke from exhaust and i hear a valve tap as well... what can i do to fix this
it sounds like you blew the head gasket on your engine. i STRONGLY recomend that you get it changed as soon as posible before your engine completely blows or ceases up.
Jun 12, 2011 | 1997 Chevrolet Cavalier
90 suburban wont start
Check your main fuse. Sounds like a short somewhere in your vehicle, but white smoke could be a few things like main fuse blowing. Computer popped. Engine blew.
Apr 13, 2009 | 1990 Chevrolet Suburban
Heating & Cooling Logo
50 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
vance jones
ghold1
Level 1 Expert
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
