Question about Pioneer VSX-305 Receiver
I had a bad speaker wire on my Pioneer vsx-305 and the 125v 6.3a fuse blew. Where could I find a replacement fuse?
  • Pioneer Master
  • 5,487 Answers
You can get fuses from any electronic parts shop, such as Maplin (UK) or Radio Shack (USA). I would get a few, because chances are the fuse did not just blow because of a bad speaker wire! Fuses are there to protect the device from an overload (which would cause a fire). The mostly likely cause of your fuse blowing is that your wire shorted out an output transistor on the channel the speaker was connected to and the transistor is acting like a piece of wire now!
If you have an Ohm meter I would put it's probes on the terminals of the transistors on the heat sink. You will soon know, as it will be just like you have touched the meter's probes together!
Posted on Apr 26, 2010
No sound from Pioneer VSX-37TX
check the caps and output transistor the power ones and resistors
May 31, 2012 | Pioneer VSX-37TX
Pioneer vsx 405 overloading whenever it turns on I checked the speaker wires and they are all OK.
vsx405 came error dc protection chacked all power transistors c2500 ,a1948 all ok i was disconnect dc detector wire then ok after few minutes one pair burned with c945100 ohms resistors that time not fix heat sink then all replaced power on error overload with speaker and without speakers also coming error disconnect ol wire no chang pease help any expert amplifiers thanks
Oct 27, 2011 | Pioneer VSX-405 Receiver
Was connecting subs to speaker connections when it popped, turned off and will not turn back on...VSX-518-k
You probably blew a fuse. It should be marked on the back next to where it tells you to turn the power off before connecting speakers.
Good Luck,
Gil
Jul 19, 2011 | Pioneer VSX-518-K Receiver
My pioneer amp vsx d508 reads overload.what to do?
Sounds like a bad amplifier IC.
Unhook all speakers at the back of your pioneer. turn it on and turn down the volume. If it's no longer in overload you have a bad speaker or speaker wires touching somewhere.
If its still in overload it's prlobley a amp IC and will cost between $25-$60 just for the part if you can replace it yourself.
Dec 27, 2009 | Pioneer VSX-D508
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Pioneer VSX-818V-K Receiver
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
I have a Pioneer VSX-454 reciever, both 1.25 Amp fuses blown
blue two legged varacter on power supply board needs to be replaced
Jul 12, 2009 | Pioneer VSX-454 Receiver
233 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
