Question about Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
Lens got dropped and the out glass cracked. Lens
Lens got dropped and the out glass cracked. Lens works find and I was able remove the outer glass. What is the part called for the out lens.
  • 63 Answers
Hi, there.
I assume you mean the 77mm FILTER that was screwed on the lens.
Posted on Apr 29, 2010
The eyepiece lenses have something on the inside. Can they be removed for cleaning?
  1. Carefully clean your binoculars by firstly removing any dirt or dust from the main body and straps using a soft microfibre cloth. Avoid the lenses at this point using any form of cloth on the lenses before removing all dirt and dust particles first could destroy them.
  1. Gently remove all traces of grit, dirt or dust particles from the lenses using a soft lens brush or canned air specifically designed for the purpose.
  1. Waterproof binoculars can be rinsed gently under a tap but be sure to use on lightly running water, avoid high pressure water as it could damage your binoculars.
  1. Gently remove any remaining marks using lens cleaning tools such as a lens pen or lens cleaning fluid and lens tissue. Do not be tempted to use kitchen towel or anything else lying around that is slightly rough and may scratch the surface of the lens, only use a lens pen, lens tissue or a lens cloth. Gently wipe the lens using a circular motion working from the centre of the lens to the outer edge. NEVER apply lens cleaning fluid directly onto the glass (always apply to the cloth) and always ensure that the lens cleaning fluid you are using is recommended for the type of lens coatings that have been applied to your binoculars (Do not use general household glass cleaning products or products designed to clean computer screens or glasses. Such products could destroy the lens coatings of your binoculars if used).
May 15, 2011 | Tasco 7x50 Waterproof w/Imp. Compass...
My child dropped the camera and now the lens is cracked. can that be fixed?
If the crack on the glass then it may be possible to replaced by the experienced service people. But you need take it to the service centre for sure.
Mar 12, 2011 | Cameras
The outer glass lens has come apart from the body of the lens. The part has a thread but I don't know how to re-assemble it. Any ideas?
Is this a completely flat piece of glass? If so, it is only what is called a filter (probably a UV filter) and is not vital to the functioning of the lens. It's an accessory that is mostly used to protect the actual front element of the lens. Filters normally have a screw thread that simply screws into the front of a lens.
If the part that has come loose is curved on either surface, then it is part of the lens and you may need to have a comera shop help you put it back.
Nov 11, 2010 | Canon EF 28-80mm f/3.5 -5.6 USM Lens
There is a cracked viewing lense.
What kind of camera is it? on most canon cameras you can remove the viewing lens and replace it. Some just snap off and some have a rubber outer piece that you can pull off and 2 philips screws to remove the hard plastic piece and glass. you can get a new one cheap off amazon.
Aug 10, 2010 | Canon Cameras
My lens is cracked on my flip cam, how do i fix it?
They aren't too hard to open up and take apart. There's a glass piece the covers the actual lens and I'm guessing that is what broke. Once the flip is in pieces you can remove the glass piece and it will operate fine without it. If you want to replace it, you can either get a broken flip and use it for parts, but there's a pretty sticky, tough ring of tape holding that glass piece in place. You could also try a very clear piece of plexiglass and cut it to size. Haven't tried that one myself, but it may work.
Apr 15, 2010 | Pure Digital Flip Video Ultra Camcorder
How do i get moister out of my 2005 equinox headlight
Take one of the bulbs out and use a hair dryer to warm both the outer glass and the inner sphere
Jan 17, 2010 | 2005 Chevrolet Equinox
Lens has been dropped with filter on it, filter shattered and has since been removed. There seems to be some glass fragments inside the lens and some slight marks on the outer surface of the lens. Lens...
Yes it is possibly only a shattered mirror inside which is easily replaced. The scratches on the outer glass can also o fix be dealt with by fitting a new lens to the frame. It wont be a cheap fix and I can only guess that you would be loooking at about 140 pounds it.
But think about claiming on your household insurance as an accidental breakage.
Please rate my help++++Thanks for using FIXYA
Nov 27, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Outer glass lense replacement
I needed the same lens. Found it at:
http://www.flexqueen.com/mov3v3cv3mv3.html
Not sure about how to fix it but I think I will find some info at:
http://www.themotoguide.com/razrdisassembly.php
Mar 14, 2009 | Motorola Mobility RAZR V3
CRACKED
The Stress of impact on the imaging forming unit that is directly behind the projection lens has a flat glass surface. If it is cracked the stress cracks would project with any image because they are on the same plane as the image
Nov 22, 2007 | BenQ MP610 Multimedia Projector
Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens Logo
229 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
