Washing machine repair
My washing machine drum does not turn. The machine fills and emptys water and i can hear a relay clicking when the motor should spin. The drive belt is on and the brushes in the motor have lots of life left in them. Where else should i look ?
  • Anonymous Mar 31, 2014
    machine has got quieter and drum not turning
    Scholar:
  • 74 Answers
Hiya .. It is probably the bearings on the drum at fault, may have collapsed... is the drum making a noise when you turn it by hand?
Regards Faggly
Posted on Mar 25, 2008
Drum wont turn or empty water
depending on the model, a broken belt is a good possibility. if you hear the motor going, but the bowl isnt moving, that is a sign of a broken belt, it is also possible the motor has failed.
Nov 11, 2013 | Washing Machines
I have whirlpool LHW0050PQ4 washer, after connect prower, start light is flash and hear click but no water in and is not working
Hello.
It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
4 Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Start wash program, fills with water, then drum does not turn.. Tried rinse progam, water ,does not turn.. Can hear relays clicking but nothin moving. But the time carries on counting down. It does drain...
If the motor is not spinning, you may have a burnt out motor or faulty Motor Control Board. Else, if the motor is spinning, fix the belt from the motor to the drum.
Oct 29, 2011 | Bosch Exxcel WFX 3267 Front Load Washer
When the washer is filling a loud noise is coming from the motor, it sounds like a bearing is going out. It seems to do it mainly when the washer is draining, but it starting to make the noise through the...
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks for contacting fixya.com
Nov 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Front loading washing machine will not tumble or spin
This sounds like a drive belt porblem. The belt that connects the drum motor to the drum has slipped/broken/worn out. A new drive belt will most likey fix this one...
Alternately, a loose or broken pulley. I don't suspect a bad motor, since you say you can hear it clicking and whiring...
Jun 10, 2009 | Washing Machines
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Dec 30, 2008 | Siemens WK61420GB Front Load Washer /...
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
