Question about Palm Treo 800w Smartphone
Palm Treo 800w freezes on boot up
Palm screen on start up flashes once when the progress bar is ~1/4 across the screen, then advances no further. Soft reset has not fixed this. Not wanting to do hard reset due to data loss. Anyone succeeded in fixing this without losing data?
SOURCE: palm treo screen freeze
Get a Blackberry and forget this inferior technology. That's what i did and i have never looked back!
Posted on May 14, 2008
SOURCE: Palm Treo 700w Verizon
do a hard reset.
Posted on Feb 12, 2009
SOURCE: my palm treo 755p
Dhorner64 is incorrect. Your phone is not fried if you are in a restart loop. You need to do a "warm reset" which will not erase data. It is the equivalent of doing a safe boot in Windows. Remove the battery from your 755p, then put it back while holding the up button on the 5-way. Hold the up button as the phone starts. I had to do this frequently, then run the DataViz Tech app, which is available free from DataViz, to fix their prefs file, which was the source of my crashes. The problem was solved by upgrading to Docs2go v11. I was reluctant to pay to upgrade a crashing app, but the upgrade ended the frequent crashes. I have not had a couple resets since upgrading Docs2go, and no reset loops.
Posted on Feb 21, 2009
  • 173 Answers
SOURCE: want to do a master reset to clear all info before
to do a MAster/hard reset you hold down the END/RED key and/while pushing the reset button with your stylus on the back of the phone, the reset button is under the battery cover, right next to the battery
Posted on Mar 13, 2009
  • 20 Answers
SOURCE: Treo 7550 - Recovery from crash without Palm Desktop Sync
no u must always hotsync every weekend, he will loose his data completly!!
srry
Posted on Sep 30, 2009
When my boyfriend was using my treo pro he put a security password on it and now he doesn't remember the password. how can i reset it?
These steps will erase all data from the device. You may want to synchronize if possible before trying these steps.
1. Take the back panel off to expose the reset hole.
2. Press Power to turn on the screen.
3. While pressing and holding End, use the tip of the stylus or a small paper clip to press and release the Reset button.
4. Continue pressing and holding End until the Erase all data? prompt appears.
5. Press Up.
6. Wait for the progress bar on to fill up, then you can use the device again.
hard reset Palm Treo 680,755,700p,800w,...etc
There is no reset button on this models like other Palm devices, so performing a hard reset can be tricky.
How to hard reset your this types ?
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/End while you insert the battery.
4. When the screen lights up with the logo appears, release Power/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo is hard reset.
Sep 06, 2012 | Palm Treo Pro Smartphone
Freezes up on palm logo
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your Treo, so only do it if you have to. Google how to do it, and it's reset.
Feb 20, 2010 | Palm Treo 750 Smartphone
Treo 650 suddenly went to a palmone boot up screen then to a palmone powered screen and just keeps repeating without fully going to the normal screen mode for the phone.
When the first screen flashes, as the bar is loading, hold up. Let go once the bar finishes. If that doesn't work you may need to hard reset. Just google how to give it a hard reset and remember that you will lose everything that isn't backed up if you do.
Feb 12, 2010 | Palm Treo 650 Smartphone
My palm treo 755p power cycles to the access powered screen
There are different types of resets that may cure this issue. Try them, starting from a soft reset.
http://forum.brighthand.com/showthread.php?t=13189
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Palm Treo 755p Smartphone
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
How do you do a hard reset on a treo 650
1. Backup your data first.
2. While holding the red hang-up key, click the reset button. Keep holding the red key until after the progress bar completes and the Palm logo shows.
3. You are then asked if you are really sure - Pressing the up key at this point completes the hard reset.
Dec 18, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Unlock Code.
Call your service provider.
Jul 16, 2008 | Palm Treo 650 Handheld
Use wifi in palm treo 680
WiFi is not supported in the 680. I understand that the Centro and the new 800W have it. (Me, I'll wait for the 800p before I trade in my trusty 680.)
Jun 29, 2008 | Palm Treo 680 Smartphone
Palm Treo 800w Smartphone Logo
315 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
