Question about Lexmark X5650 ALL-IN-ONE PRINTER
How to Fix a Carriage Jam on a lexmark x5650 - Lexmark X5650 ALL-IN-ONE PRINTER
  • 4,041 Answers
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
  • 1,218 Answers
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Michel
Posted on Oct 07, 2010
5 Suggested Answers
ghassun
  • 499 Answers
SOURCE: i have a paper jam in my lexmark x5650
hi try firstly to open the paper mount and then put ur hand to see if there is a paper jam there if not, try to open the color cartridge mount and remove the colour cartridge and install it back again if not, try to turn it off and on again.
Posted on Jun 07, 2009
pineworks
  • 4041 Answers
SOURCE: Lexmark X5650 All-In-One InkJet Printer
Hello there You can try see if this may do the job. This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Posted on Apr 26, 2010
pineworks
  • 4041 Answers
SOURCE: Lexmark X5650 printer
Hello there
ok try this my help you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Printtech
  • 1087 Answers
SOURCE: Lexmark X5650 All-In-One InkJet Printer has a
Hi. Here's an article in the Lexmark website that might help you out with the carrier paper jam problem. Just go to this link http://bit.ly/btHg8D. If you have tried all of the troubleshooting steps found in the article but still getting the same problem, you might be having a printer mechanical problem. If that's the case, I suggest you call Lexmark at 1-800-LEXMARK(1-800-539-6275) for assistance. Make sure to take note of the serial number found behind the printer.
Lexmark 5660 paperjam
printer says paper jam no paper in printer i have on pluged it to clear it and its continueing to say paper jam what should i do?
Oct 20, 2012 | Lexmark X5650 All-in-One InkJet Printer
What can I lubricate the cartridge carrier bar with?
Just about any lubricant, spray or paste; it's usually bronze sleeves and a steel rod.
Don't spray directly, put some lubricant on a tissue and wipe the rod, then move the carriage back and forth a couple of times (printer off). Repeat on the other side of carriage.
Sep 20, 2010 | Lexmark X5650 AllInOne InkJet Printer
How to free carriage jam on lexmark X4550
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.fix Lexmark Carriage Jam .
Sep 18, 2010 | Lexmark Office Equipment & Supplies
Lexmark X5650 All-In-One InkJet Printer has a carrier paper jam how do i fix it
Apr 25, 2010 | Lexmark X6575 All-In-One InkJet Printer
I havw a lexmark x5650, how do i get the fax to print out of the memory
my printer lexmark x5650 says the carrier is jammed how do i fix it
Mar 19, 2010 | Lexmark X5650 All-in-One InkJet Printer
My lexmark x5630 x56xx series displays carrier jam the carrier bangs to the left, i saw a thin strip of plastic in the printer looks like its broken off from something please help
just try to fix it .but i think it is broken so you need to replace the broken part i advise you to show it service center.
Have a nice day and do not forget to rate please...!
Feb 03, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
My Lexmark X5650 all in one printer displays a paper jam error but there is no paper jam. And I can't seem to get it to disappear after turning it on and off and unplugging it.
Inspect entire paper path for even a little shred of paper. All it takes to block a sensor, or hold down a "finger". if nothing at all, could be one of the sensors are faulty or unplugged.
Sep 21, 2009 | Lexmark X5650 All-in-One InkJet Printer
I have a lexmark x5650 and evertime I try to print something the paper will feed through on one side and not the other so it doesnt print properly. also it says paper jam. any ways to fix this??
if you have a paper jam error and you don't see a Jam it means the printer just needs to be reset.
Please try this to do a partial reset. Leave the printer on and then unplug it and leave it unplugged for about 1 minute and then plug it back in and turn it back on and see if the problem persists.
About the paper feed, first check the printer preferences, go to start, select printer and faxes. Mark the Lexmark printer, click right mousebutton and select properties from the menu list.
Check that you have set paper size to DIN/A4 and adjust your other settings as needed.
If the problem persist check if you have the latest drivers installed, if this doesn't help I think you will need to contact lexmark support.
Aug 26, 2009 | Lexmark X5650 All-in-One InkJet Printer
I have a paper jam in my lexmark x5650
Jun 07, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark x5650
http://support.lexmark.com/perl/support/support.cgi
please click on this link, and type in your printer model to get the Chat support agent, who can fix this for you.
Jan 11, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5650 ALL-IN-ONE PRINTER Logo
2,122 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
