F-02 fault code on indesit we16 washing machine
I keep getting the fault code f-02 on my indesit we16 washing machine. what is the problem and how can it be fixed?
  • cheadle_red Apr 13, 2008
    I have just come back and discovered the washing cycle aborted and the screen displaying F-02 error. THe door was not locked and we took out the load: which was soaking. The machine is now going through in a spin cycle with noting in it.
    F-02 is an eror could but what is the error?
  • marysfoodhav Jan 26, 2009
    Ok so I have the same problem but how do I fix the jammed motor or faulty tacho
For what it is worth my WE16 often stops with an F-02 display within 3 minutes of starting, but only in summer months. Powering off and restarting usually cures it, and it will then go on to run several loads without problem. I keep the machine in my cellar boiler room, and attribute the problem to high humidity when the boiler is not running. Changing the PCB does not cure the problem, nor does protecting it against humidity (eg poly bad and silica gel). I conclude that moisture getting somewhere unexpected (tacho perhaps?) can cause this error.
Posted on Jun 12, 2010
Motor rotational speed is not satisfying tacho. Could be motor brushes worn (quite easy to check from underneath machine WITH POWER OFF, using crosshead screwdriver, 15mm minimun length), motor or drum bearings seizing, motor windings going down, faulty tacho or speed contoller circuitboard.
Posted on May 10, 2008
According to info on a similar site to this, it means motor jammed/tacho faulty or detatched
Posted on May 08, 2008
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
I have an Indesit WIA111 and the pre was/ wash LED light keeps flashing when machine is not on can you help
try the reset by unpluging it and plug it back after one hour.
check your manual for fault codes.
tnx 4 using fixya,
Oct 04, 2008 | Indesit Washing Machines
I have an f-02 fault code on my indesit evolution 1200 we12 wasing you know what this means? Julie
In my lists Indesit's 'F02' stands for 'motor jammed/ tacho problem, check leads' meaning that it is requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 21, 2011 | Indesit Washing Machines
Washing machine drum movement
It can be tightened from the rear pulley.
May 23, 2010 | Washing Machines
F12 code problem with indesit we16
F12 means no communicastion between boards.
Check all connections and wiring between the boards.
Good luck
Dec 14, 2009 | Washing Machines
How to replace bearings on a indesit we16 washing machine
the bearings on this appliance are fitted into a 4 legged style carrier,this is remove by removind belt and pully then there are 8 torx type screws holding the carrier on(2 screws on each leg).
then pry off the carrier.take care as the area around the tank and cabinet are very sharp.
Aug 04, 2009 | Washing Machines
Washing machine fault
lg trom showing E and on display won't drain
Mar 26, 2008 | Washing Machines
Washing Machines Logo
1,690 people viewed this question
Top Washing Machines Experts
