Question about Belkin Computers & Internet
Laptop is not currently wireless for whatever reason every light is on except the wireless light...
    President:
  • 1,768 Answers
1. check the "wireless" and is it turned on
2.. check the task bar and see if the wireless icon on
there will be a cross on it if it is disabled.
Posted on Apr 26, 2010
PC will not go wireless
If your PC is a desktop, not a laptop, probably it can be hooked to your modem/router only wired (using an Ethernet cable). If, for whatever reason(s), you want to connect it wirelessly, you have to buy a USB wireless adapter.
Jul 07, 2014 | Belkin (F5D8231-4) Wireless Router...
What color wires go to power switch and circuit breaker
If you use the code of NEC(National Electric Code) will be Red and Black and white.
However will be differences with this. In short black to any point and red to any pointsince you are trying Alternating Current VAC , There are No polarities need it,such inContinue Current. VDC, you must be carefully to conect the white wire to ground, will VERY CRITICAL.You can conect whatever will be the color in any point except the white color.sincerely.Will be a good idea for you to open the Male receptacle from power cord, and follow the wires codes. Except the white for the reason explain. If the wires changes for examples to yellow-green this will be the ground instead of the white.
sincerely.
Nov 21, 2011 | Nordic Track Nordictrack Exp 1000...
I have a clevo Prostar laptop and it wont start. On power on the lights on the key board light up, blue tooth gets checked, wireless gets checked the I hear two short beeps and the display wont light up...
It's possible that the LCD isn't working for whatever reason. If the computer is POSTing fine (Power-On-Self-Test it's what the two beeps symbolize generally) then it's likely that the LCD isn't functioning. My recommendation will be to hook an external monitor up to the laptop and see if you get video from there.
Mar 21, 2011 | Computers & Internet
Cant find wireless butoon?how do i switch it on????
it's not a button you need to conect to the internet through a wired connection and run windows update to update your wifi card driver. i know it says it's switched off but for some reason it says that when you have the wrong driver. the button next to your power button is to turn on hp wireless manager or helper or whatever they call it. it's a pain but to go wireless you need to go wired first. once you've updated you need to wait for about 5 mins after your laptop reboots and the orange wireless button will turn blue
Jan 11, 2011 | Toshiba Satellite A60 Notebook
How does the epad connect to the internet
Hello mhille. Whatever method you are currently using to connect will work for the epad. You can connect wirelessly or with a cable to your modem. Joe
Thanks for choosing fixya!
Nov 24, 2010 | Computers & Internet
My Mac laptop can go wireless with any network except my home wireless. It did for a while and then I don't know what's happened. I type in the password for the network and it says wrong password even...
Try unplugging the wirelss router power and replugging back in to reset the system. Then try using the default password, which is usually the long serial # on the router. Alternatively, you can call your service provider and have them reset the password for you to get in and then you can change it to whatever you want. Also, for some strange reason macs want you to put a $ sign in front or sometimes in back of the password.
Sep 13, 2010 | Apple MacBook Mac Notebook
Sporadic internet wireless connection
Have you tried putting the computer in to safe mode. I had the same problem with 3 other laptops but all the same model. I think it has something to do with an update. I put it into safe mode and rolled back the driver and its working fine
Feb 17, 2009 | HP Pavilion dv6000z Notebook
DI-524 not working with Vista32 Dell M1330
make sure your wireless card is set to "obtain automatically an IP address"
Jan 25, 2009 | D-Link AirPlus DI-524 Wireless Router
No Light
either an IP conflict try using DHCP or you will need to reconnect with the laptop and add the wep Key or whatever encryption key/keys are set.. problem solved make sure your laptop support the type of security you have set...
Aug 19, 2008 | Symbol Spectrum24 Wireless Neworker...
Belkin Pre-n wireless router
Check your device to see if it is due for a firmware upgrade. Esp. depending on your ISP, log into your device that you have from your ISP ( whether dsl modem, cable modem, etc.) and then follow whatever procedure it needs to determine your current firmware version.
Jun 16, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
