Question about GE DBXR463EBWW Electric Dryer
GE dryer drum hits idler pulley during rotation.
    Habit-Forming:
  • 98 Answers
The belt is most likely either the wrong size (too long) or the belt has stretched. A new belt of the correct size should solve this problem. Make sure you have the model number when you buy the belt. I recommend that you take the old belt with you and verify that the replacement is a little shorter.
Posted on Apr 29, 2010
How to remove front idler
Dryer Idler Pulley (part #691366)-How To Replace - YouTube
? 6:06
https://www.youtube.com/watch?v=YoJ7k30kXhE
Nov 14, 2011 - Uploaded by AppliancePartsPros
Buy the new Dryer Idler Pulley 691366 ... We did not have toremove the rear panel with this design, it was ...
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ...
? 2:53
https://www.youtube.com/watch?v=RZ09dH4-7Ho
Jul 6, 2010 - Uploaded by RepairClinic.com
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ElectricDryer Repair .... If the belt is around the drum ...
Dryer Idler Pulley Replacement - GE Dryer Repair (part ...
? 3:37
https://www.youtube.com/watch?v=bm8s2vVuxvk
Sep 17, 2012 - Uploaded by RepairClinic.com
The most common reasons for replacing the idler pulley... ... GEdryer tune up, belt, drum bearing and front ...
Dec 25, 2015 | Dryers
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
THE DRYER DOES NOT WORK, IT DOESNT SPIN BUT MAKES A NOISE
richy wilson, the motor may be burned out. I think that the lid/door switch isnt the problem. If it is faulty, the dryer shouldnt do anything at all when started.
The first thing I would do would be to gain access into the dryer by removing the top panel and then the front panel. Check to see if the belt is still in one piece or severely worn.
You will probably need to test the motor. You can do this several ways;
1. remove the belt if it is in good shape.
2. check for obstructions in the blower fan housing (usually in the lower left corner. looks like a circle with fan blades throughout)
3.manually rotate the shaft of the motor, if it is stiff then you'll probably have to replace it.
4. if the motor rotates freely, try to run it momentarily with the belt removed. if it does rotate fine, then there may be a problem with the idler pulley or the drum itself. the idler pulley is usually a little wheel that holds the tension of the belt onto the drum.
5. try to rotate the drum by hand. if it is difficult to move, try to correct any problems with the rollers or idler pulley.
6. If motor hums but doesnt rotate on its own, even with the belt removed, yet you can turn it freely by hand, you usually will need to replace the MOTOR, or MOTOR START CAPACITOR.
If you have any further question, feel free to email me. If you do, try to include the model number of the dryer.
thanks,
mike
Jul 08, 2011 | Washing Machines
Dryer squeqks while rotating
It could be a noisey idler pulley that belt rides on, or a noisey drum bearing or drum glides, or even possibly a motor bearing going bad. Would need to be checked by repairman to determine exact cause.
Feb 04, 2010 | GE DBXR463GB Gas Dryer
A constant clicking noise near the motor of my maytag dryer. seems something is slipping as occasionally the drum and belt slow down
It sounds as if the idler bearing has started to fail see this picture http://sites.google.com/site/sublimeappliancerepair/_/rsrc/1246721031553/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info/Norge%20dryer%20with%20drum%20removed.jpg
The idler pulley in the picture is behind the motor.
I would check the ilder pulley to see if it rotates freely and does not have any odd side to side movements. If it does then replace the idler pulley and belt.
Belt: http://www.appliancepartspros.com/part_details.aspx?part_id=4043963&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d47809%26diagram_id%3d681078
NOTE: Before you remove the idler pulley and belt note carefully the installation position of the belt, idler arm, spring and the idler pulley. For a first timer trying to do this it can be quite frustrating to get them all positioned correctly.
Idler pulley:
http://www.appliancepartspros.com/part_details.aspx?part_id=4373393&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d49146%26diagram_id%3d673577
I hope this has been useful information to you. Good day.
Jan 06, 2010 | Washing Machines
My dryer squeaks loudly when running. I have
Yes .I would say its the jockey pulley @ fault..
Nov 22, 2009 | GE DVL223EBWW Electric Dryer
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Need a btlt route so i can put the new drum back in my ge profile
route the belt around the drum, pull the spring loaded idler pulley to the postion that requires you to hold it there..
put the belt : 1 through the motor pulley and around the idler pulley, or 2. around the idler pulley which ever works to keep the tensioner tight. (Idler pulley, tensioner same thing its the pulley not on the motor.
Once you put the belt on the durm, pull the idler pull so there is tension on it it should be clear how it goes.
Doc
Feb 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Idler pulley arm
there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.b00f604.jpg
Jul 19, 2008 | GE DBSR453EBWW Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
88 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
