Question about Maytag 25.1 Cu. Ft. Bottom-Mount Refrigerator - Black
My freezer is making a continual "creeking noise" that quits when I open the freezer drawer. Any ideas what the cause may be and how to make it quit?
    Scholar:
  • 126 Answers
I HAVE SEEN 3 THINGS DOING THIS. ONE IS THE BACK PANEL INSIDE THE FREEZER. IN WHICH I REMOVE THE PANEL AND ADD SOME MORE CUSHIONED TAPE. SECOND IS THE COILS UNDER THE REF. MAKING CONTACT WITH THE CAINET OR FLOOR. MOST COMMON IS THE EXPANSION AND CONTRACTION OF THE TUBING IN THE FREEZER WHICH CANNOT BE FIXED.
Posted on Apr 25, 2010
Away for 3 days, came home, all food in freezer just slush. Fridge OK, freezer dead. not sure why, maybe not quite closed door. Fan in freezer was not working but it has suddenly come to life.
Yes, leaving the door open a little could cause it to defrost. This would also make the fan run more than usual, and the fan might have run so much that the fan temporarily stopped working. This is probably a built-in safety feature of the fan (much like some paper shredders will overheat and not return to operation until you let it cool down or operation environment turns back to normal). Good luck.
Jan 03, 2018 | Refrigerators
Monogram DISP480DXASS jack hammer noise behind the Climate Control Drawer.
By the way you discribe it, it sounds like it's going into defrost mode check and make sure freezer side isn't iced over or that the drain isn't iced over if it's a side by side drain should be at the very bottom of freezer side usually hidden behind a piece of plastic if it's a top and bottom the drain will in the freezer very back bottom also hidden hope this helps
Mar 04, 2016 | Refrigerators
When light button is pressed, there is a woof noise
guess what / your right / have a chat with the co that sold it to you . I d let the woof out of the freezer and then it would weigh less and the drawer would slide easly . problem over .. , not quite . this is a quality product and you should expect it to be . draw's should be smothe ect . look for damage to outside and frame if found have them replace it . mm
Jan 16, 2010 | LG LDC22720ST Stainless Steel Bottom...
My Hotpoint ffa40x fridge freezerhas a problem,the freezer gets a build up of ice inside the freezer under the bottom drawer which makes the drawer stuck fast until i cut through the ice to release it.This...
your auto defrost heater is not working or you need to defrost it yourself ... turn unit off for a day with doors open. ***********PUT YOUR FOOD IN SOME ONES ELSES FRIDGE ************
Dec 30, 2009 | Hotpoint Refrigerators
Quit working -Haier Freezer
You have one of three issues here.
Either the thermostat has gone bad,
The thermal cutout has gone bad ontop of the compressor,
or the capacitor is out for the compressor.
Take an hom meter and check the thermal cutout, it should read 0 ohms or "continuity" if it doesnt the cutout is bad.
The only real way to check the cap is with a cap meter.
as for the thermostat check it with a n hom meter to make sure you have good connections internal the thermostat.
If you have any other questions just let me know!
Mar 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Sep 29, 2006 | Hotpoint FFM90 Bottom Freezer Refrigerator
Maytag 25.1 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
73 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
