Question about HP OfficeJet 6110 All-In-One InkJet Printer
I have an hp 7310 all in one..I had a paper jam, cleared that, now I keep getting the carriage jam message..it acts like the cartridge is jammed ont he right and won't move..when I turn it off and on and lift the cover I can see the sensor trying to move but it is stuck??
  • 4,041 Answers
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
All The Best: Pineworks
Posted on Apr 25, 2010
How do i clear a carriage jame an ,sg find nothing wrong
Click the link below to go to the hp printer support page for your printer paper jam. Pay special attention to the rear door , as many people miss that detail when clearing paper jams.Also , you can click on the troubleshooting link at the top of that page, followed by "solve a problem " in the drop down box to get answers for other problems,
Clear carriage jam and press OK to continue Error Message Appears for HP...
Feb 14, 2015 | HP OfficeJet 7310 All-In-One InkJet...
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My 7310 indicates a carriage jam. I've cleared all paper and verified no loose paper, dust etc is present and it still reads carriage jam. What should I do?
Inside your printer the ink cartridges ride in the carriage. If you look closely, there is a plastic strip just behind the carriage with closely spaced little lines on it. If the strip gets dirty with dust or ink, you may get that error. Gently clean the entire strip with a rag moistened with water. be sure the entire strip is clean. Move the carriage back and forth to get at all of it. Then see if that doesn't work.
Nov 27, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Have a HP officejet 7310 with error message that reads "carriage jam" this occured after clearing a paper jam???
You have to make sure you have gotten all the scraps out, and if you put fingerprints on the clear strip behind the carriage, you will need to clean them off with a Q-tip.
Jul 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage Jam
If you can get the covers off. push down on piece that is blocking the cartridges. Otherwise, it is uneconomical to repair.
Jan 15, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp 7310
Find the stuck piece of paper and remove it.
Dec 21, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Carriage Jam
Without knowing what type of printer we are dealing with, what paper try layout etc etc.. I would suggest you try replacing your pickup rollers.
Nov 23, 2008 | HP Officejet 7310 All-In-One Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
179 people viewed this question
Seeker5211
Seeker5211
