Question about Sanyo DP42746 42 in. Plasma Television
Sanyo avp4232 push power on, red light in front turns to blue, screen is black and cannot access menu or any other control
SOURCE: 15 DAY OLD TV
Specifications Key Features Screen Size37 inch Contrast Ratio1,000:1 Flat Panel TypeLCD Television Display Resolution1366 x 768 pixels LCD Response Time8 ms Display Capabilities Built-in TunerNTSC · ATSC Broadcast Format Displayed480p (EDTV) · 720p (HDTV) · 480i (SDTV) Native Aspect Ratio16:9 Image Quality Brightness500 cd/m²
Posted on Feb 04, 2008
ginko
  • 19396 Answers
SOURCE: Sanyo DP42746 - Screen went black and no sound. Power light on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Jun 16, 2009
  • 7 Answers
SOURCE: Sanyo CE26LD81B 26 in TV keeps going from a red
Press the Menu button on your remote control. It happened to me and worked.
Let me know how you get on.
Matt
Posted on Jul 19, 2009
  • 135 Answers
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Posted on Aug 23, 2009
budmrtn
  • 11361 Answers
SOURCE: DP46849 has black screen with power light on.
It may be in safety shut down mode due to shorted circuits or power supply failure due to such thing as bad DC filter caps. You will need to do in-depth troubleshooting.
See www.shopjimmy.com if he has the picture of the boards.
Please read my guides also.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 23, 2011
Safe/dynamic mode appears on the screen for half a second
You have a power supply problem.Most brand they have modules.
If you can open the back you will see a few separated Modules.You
will see a power supply module just replace it Take note of the connectorsThey have letters usualy to match the plugs.
By the away do you have any sound?
Nov 01, 2012 | Sanyo Televison & Video
The picture has a red color
You need to First turn Color Off In the Menu then, Find the Screen and Focus Control Block
adjust the Red/Green/Blue Screen drives To a Black and White Picture, Then Go Back to Menu -Color and turn Color Back on.
Remove the Front Bottom Panel and Control Block is behind it. It will have 3 controls on top for Focus and 3 under them for Screen Drive to each Tube R/G/B
Jan 25, 2011 | Hitachi 57F500 57" Rear Projection...
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Need to clean lenses and do manual focus/alignment of guns on a VS-5055. How do I get access to them and adjust? Thank you.
the lenses are accessable by removing lower back of unit,clean them with a damp paper towel-wipe them off with a dry one.put back back on unit.
screen/focas controls are in front of unit.remove speaker grill remove black cover using phillips screwdriver.you will see 2 sets of controls.one row is focas.one row is screen controls.red,green,blue.turn each focas control slowly to get the clearest picture for each color.screen controls are touchy(if you turn then too high unit will shut off)if the black and white picture was good i would not adjust screen controls.if it was bad turn blue and green screens down all the way.picture is now red turn green up until it turns yellow then turn blue up until it turns white
Sep 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
There is a green tint to my screen. Seems to be more evident in dark shows and on shadows.
Pull the front speaker grille off and remove the access panel. In the customer menu turn the color off so you have a black and white picture. get a flashlight and adjust the screen controls for the red, green and blue tubes until you get a nice black and white picture. then turn the color back up.
May 26, 2009 | Hitachi 51F59 51" HDTV Projection...
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Televison & Video
Sanyo DP42746 42 in. Plasma Television Logo
319 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
