Question about HP Photosmart 3210 Printer
Shows printer not connected when it is
    Brigadier General:
  • 10,406 Answers
Change the cable between the computer & the printer.
Try connecting to a different port on your computer.
Try connecting the printer to a different computer (laptop?).
If all else fails, take the printer to a qualified technician, for better trouble-shooting.
Posted on Apr 25, 2010
My Epson Label printer is showing as not connected when its connected, when trying to set up or add as new printer.
What shows mac and ip address ? printer or pc ?
If the printer displays them, it means the printer in connected to router electrically.
Check subnet mask and gateway address.
Could be set wrong if the router is not on DHCP.
I guess the issue is in the ethernet components / settings.
Start isolation by elimination of the following
1. Computer -
2. Wifi connection to the router (or)
3. Patch cable connecting computer to the wall -
4. Router -
5. Patch cable connecting the printer to the wall -
6. Printer -
The LAN printer cannot connect to Computer (PC/Mac) directly unless you use a Cross over cable.
Sep 11, 2016 | Epson Tm C3400 Securcolor - Label Printer...
After refilling and fitted to printer. The Printer shows complaint "No Printer Cartridge"
due to dust or carbon sometime printer show warning message after refilling. you must clean it carefully or attach it again. if still problem will not resolve, clean your area of cartridge with some cleaning liquid that connects with printer (silver or golden area which have pins) and connect. if your printer is working but jst showing message about cartridge is not original or printer have no cartridge then plz ignore that message.
Sep 26, 2014 | HP 12A Toner (Q2612A) Printer
MY CANON PRINTER SHOW PORT TO WHICH PRINTER IS CONNECTED IS NOT SUPPORTED
call any soldering expert and re solder the dry joint of your printer's usb base.
Aug 28, 2012 | Canon LASER SHOT LBP-2900 Printer
Hi, i am aman from bangladesh. while i setup the software of my printer hp deskjet d1660, it shows me a massage that connect your device and make sure that printers power on, i connected it to usb port...
if ur printer is connected and detected once
go to device manager
it show yellow on that princter number or unknow device just right click and install drivers from cd rom or automatically
Jul 18, 2011 | HP D1660 InkJet Printer
My printer can not print. I tried to follow troubleshoot and restarted the spooler nothing happened. It showed the message that says "printer lost its connection to server" the name of the...
did you already try all the set up of your printer?. you said showed error message lost its connection to server that means you need to re install your printer to access the server. you need the CD installer of your printer then run the software so that your printer can now connect to server.
Apr 12, 2011 | Office Equipment & Supplies
Printer is connected and on. Shows as offline.
Go to Control Panel
Open Printers and faxes
Right click on your printer icon
Uncheck Use Printer Offline
Check if the printer is working ( A restart may be needed)
Oct 06, 2009 | HP LaserJet 3055 All-In-One Printer
Printer will not function fron computor . I shows than it shows error.
Hello my friend, regarding on your problem try to check the connection of your printer if it is properly connected. Then try also to check if that printer is online and installed properly cause the main reason why printer won't work is either the connection is not properly connect or printer driver not installed properly.
Jun 16, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Sep 18, 2008 | Microsoft Windows XP Professional With...
Blinking light -no connection
reinstall your printer drivers
Sep 02, 2007 | Lexmark Z600 InkJet Printer
HP Photosmart 3210 Printer Logo
88 people viewed this question
Seeker5211
Seeker5211
