Question about Sony Cyber-Shot DSC-T1 Digital Camera
First my lens was stuck. After releasing it, the lens keeps coming out and going back in, Than gives an error message saying 'turn camera off and back on again' but this doesn't help. What to do?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 25, 2010
My d90 flashes an err sign somtimes when i shoot at manual mode.. but when i change my apperture and shutter speed setting, it will not appear anymore. Even at auto mode sometimes it flashes an err. Does...
Try shooting in manual mode with lens set at maximum (wide open) aperture. Then try at a smaller f-stop, say 5.6 or 8. If the error message appears when your lens is set to the smaller aperture, you could have a lens problem. Try another lens using the same test. If a known good lens gives an error message, then the problem is in the body. Also try zooming to different focal lengths and see if your 18-105mm gives the error at particular focal lengths. An error here would indicate a lens problem. In any case, your lens or body would have to be repaired by a professional as these repairs require major disassembly and re-calibration.
Nov 19, 2010 | Nikon D90 Digital Camera with 18-105mm...
I have a fuji A100 10.0 megapixil digital camera. am getting zoom error message and cant get camera to do anything..can you help
Owners manual says "zoom error" indicates a camera malfunction. But, try this, gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur.
Also, sometimes you may have to try several times until you finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Mar 19, 2010 | Fujitsu Cameras
Lens Error
If you are sure that your battery is fully charged but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Nov 11, 2009 | Canon PowerShot A550 Digital Camera
Lens error message. lens stuck open; gives a lens error message & must remove batteries to turn off
This seems to happen when something (water, sand, dust)
gets trapped in the lens mechanism.
Has the camera been somewhere filthy before?
The recommended methods include taping on the
bottom of the camera,rapping it on a table,
and pressing hard on the lens.
If the lens moves when you turn the camera on,
try keeping your hand on it so that i
t's forced back into the camera body.
A can of compressed air squirted around the
lens is also a possible fix...
but be super careful with that stuff,
a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff
to your camera, but if you're careful you may
be able to get it working again without having
to get it serviced.
Jul 06, 2009 | Nikon COOLPIX L10 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Casio camera lens stuck
hi
this is repairable u ask ur near servicecenter
Feb 18, 2008 | Casio Exilim EX-S500 Digital Camera
I fix digital cameras call 214-650-6531 or email me at mike@digitalcamrepair.com
Feb 06, 2008 | Casio Exilim EX-S500 Digital Camera
Lens error No. 221,0,0,0
I have Pentex Optio E 30 camera
When i start my camera , i get error message Lens Error : 221,0,0,0
lens got stuck and it is not coming out for zooming
Sep 06, 2007 | Kodak EasyShare C703 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
51 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
